V5 beta Apr-13-2023 available now
 1-18  19-38  39-58  59-78  79-98  99-118  …  219-223
11056.59 In reply to 11056.57
Nice
the next iteration will also be fixes. Or will there be direct modeling? And when will it be?
11056.60 In reply to 11056.59
Hi blackboard,
Probably mostly fixes as well for the next couple of betas.
I don't know precisely when they will be released.
11056.61
not sure if the counts as a bug. i created a sphere, cut a section off, copied it, fillet the new edges, one as acis one as solid. the solid works well, the acis is lumpy on the not filleted section. when i mesh both of them the acis is not smooth whereas the solid is perfect.
Val
EDITED: 11 Jan 2024 by VAL2
11056.62 In reply to 11056.61
Try to rotate the curve generator! ;)
11056.63 In reply to 11056.62
It's on purpose not on the curve generator.
11056.64 In reply to 11056.61
Hi Val, this is probably a bug in ACIS filleting, in the conversion from ACIS geometry back to Solids++ geometry.
Do you have a version of this file before doing the fillet?
11056.65 In reply to 11056.64
No, but it's easily replicated. if you look at the file you can see where I cut the sphere with a line. I have done it a number of times, always with the same result on the bigger section.
11056.66 In reply to 11056.65
Hi Val, thanks - I can repeat it over here although it's not quite as messy as your version. It should be good enough for me to debug it though.
11056.67
Hi Michael.
I'm having a problem with filleting the six holes on this part. The flat rear face works OK, but not the front face. The fillet size I'm applying is 1mm.
Martin.
11056.68 In reply to 11056.67
Hi Martin,
Can you please check which version of Moi you are running?
The front edges are working ok for me in the current Apr-13-2023 v5 beta.
11056.69 In reply to 11056.67
Hi Martin.
It is necessary to replace the surface, for some reason it prevents rounding.
The same is true for the chamfer.
https://disk.yandex.ru/d/uJfij4c_N_WDug
In version 4 , it can be done this way ...
image host
EDITED: 24 Apr 2023 by WN
11056.70 In reply to 11056.68
Hi Michael.
It might have helped my query if I'd used the right word... It is actually a 1mm chamfer that I can not get to work on these six holes, so please accept my apologies for sending you off in the wrong direction. I'm using the V5 beta Apr-13-2023.
Martin.
11056.71 In reply to 11056.70
HI blowlamp
You can't do the chamfer because forms are not circles and not cylinder
Please take a look on the next files and try to make the chamfer
Chri
Size: 73 KB, Downloaded: 92 times, Dimensions: 571x475px
11056.72 In reply to 11056.71
Hi Christian.
Whatever you did made it possible for me to chamfer those holes, so thank you for looking into this for me.
It still leaves a mystery though, as the holes were created from circles generated by MoI.
I positioned the first circle at 12 O'Clock on the front face and Circular Arrayed the other 5. I then did a Boolean Merge to cut the holes from those 6 circles.
I just tried remaking the solid from the Revolve curves and then using 6 fresh circles from an Array. The result is still the same for me. :-(
Thanks again.
Martin.
With the file of the Start...thread
https://moi3d.com/forum/index.php?webtag=MOI&msg=11056.67
I select all the perimeters then Fillet (1mm)
Fails with the Solid++
No problem with the Ascis ! ;)
EDITED: 24 Apr 2023 by PILOU
11056.74 In reply to 11056.73
Hi Pilou.
Try it with a Chamfer instead of a Fillet.
Martin.
11056.75 In reply to 11056.69
Hi WN.
Thanks for trying to solve this for me.
It seems like there might be a problem with where the holes are positioned on the front face. If I redo the layout, so that one hole in the group of holes is positioned at 3 O'Clock, rather than at 12 O'Clock, then the Chamfer works OK.
Martin.
11056.76 In reply to 11056.75
Hi Martin, the problem kind of originates from the Revolve, because the plane that you're drilling holes into is being created as a surface of revolution that is flat rather than as an analytic plane surface.
There is a mechanism in Revolve that is supposed to replace those surfaces with a trimmed plane surface but it does not appear to be working here, I am investigating it.
Thanks, - Michael
11056.77 In reply to 11056.74
Indeed that fails with Chamfer!
I redraw from 0 the disc /cylinders... not on the generator curve (maybe not the root problem but more prudent! :)
(not the groove piece you can copy it if necessary...
like this all perimeters are plenty and not trimmed! ;)
So
No problem! :)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/flange1.3dm
there are 2 models for make yours tests!
Solid ++ or Acis
Chamfer or Fillets 1 mm
Show messages:  1-18  19-38  39-58  59-78  79-98  99-118  119-138  …  219-223
