V5 beta Apr-13-2023 available now
 1-9  …  150-169  170-189  190-209  210-223
11056.190 In reply to 11056.189
Hi Alex, can you please send me an e-mail at moi@moi3d.com ? I'll prepare some test builds of earlier v5 versions if you are willing to test them out to hopefully pinpoint what caused the change in network behavior.
11056.191
I only started using any of the V5 betas in the last few weeks. Running the Dec-1-2023 beta right now, I notice a considerable lag navigating the viewports and the UI in general. The exact same file will feel more sluggisch in V5 compared to V4. I don't know what changed to cause this (perhaps the grouping functionality?). Also, I can hear the fans of my Macbook Pro spin up when working, which it never did on V4.
Any thoughts?
11056.192 In reply to 11056.191
Hi Fabien, can you please e-mail me (moi@moi3d.com) your moi.ini file?
Also is it an Intel or ARM machine?
Thanks, - Michael
11056.193
Same thing with Linux WineHQ, I can't use version 5 and I've tried everything, we've already exchanged messages but none of this has ever resolved anything.
11056.194 In reply to 11056.193
FWIW, I've been running Moi3D on Ubuntu 20.04 under Wine since version 7 without incident. Currently running Moi3D V5 with Wine development version (9.1) which I've been doing for a few years as I found performance was better without any reliability problems. In the beginning I would thinker with moi.ini settings, but for quite some time have been running defaults as it just seems to work. The only very small nuisance is the "view controls window" which sometimes will stay in foreground of native Linux apps, but it is harmless. I would try restoring defaults in both Moi3D & Wine.
Sven
Crash occurs for my .3dm file, in MoI5beta, and in MoI4,
If there is one or more construction lines active,
and if an attempt is made to change General > Unit system: (from feet to meters, or vice versa)
Crash report was sent, and also emailed.
11056.196 In reply to 11056.195
A simple rectangle in MoI4, plus a couple of construction lines, and NO dimensions added, also causes a crash.
I was using shortcut key Ctrl+Alt+C _ConstructionLine
(maybe that is the problem?)
So I guess my question is, where is the documentation of how to create and do a construction line.
Where is the latest construction line script. (mine looks like 2009 version?)
ConstructionLine3 link:
https://moi3d.com/forum/index.php?webtag=MOI&msg=1029.25
EDITED: 15 Feb 2024 by BEMFARMER
11056.198 In reply to 11056.197
Hi Brian, thanks for reporting this crash. I think I've got a fix, I've sent you a test build.
The construction line docs are here:
https://moi3d.com/4.0/docs/moi_command_reference11.htm#constructionlines
I think there are links here:
http://kyticka.webzdarma.cz/3d/moi/#KeepCLine
11056.199
Hallo Michael,
steht schon ein Termin für die Moi v5 an.
LG
Pit
11056.200 In reply to 11056.199
Hi Pit, sorry there isn't a final v5 release date set as of yet.
I'm still in the process of working on the ACIS integration.
11056.201
Hello,
I would like to report a bug.
When you copy an object from within a group, paste it (do not move), select come face, and delete it, the whole group gets duplicated upon deleting the face. Only disabling history for the duplicated object, or moving it prevents this bug from occurring.
I love new beveling capabilities.
See ya
11056.202 In reply to 11056.201
Hi Fubax, thanks for reporting this bug. I can reproduce it over here, I will investigate it. It looks like the pasted object still thinks it is part of the original group.
Thanks, - Michael
11056.203 In reply to 11056.202
Hi Michael, there's also similar thing happening sometimes when I Ctrl+z deleted objects, they get multiplied each time I undo. Maybe that's related, but I don't know any specific conditions to recreate that, it seems to happen in more complicated projects. ¯\(°_° )/¯
11056.204 In reply to 11056.203
Hi Fubax, I've seen the undo multiplication, I think it's not related to groups.
It's on my radar to get fixed too though.
Thanks, - Michael
11056.205
I would like to report another bug, now with the pinning of "Unnamed" objects.
• When nothing is selected and you Ctrl+Left click on the "Unnamed" right side in the objects list, there's no pin icon, but nothing can be selected afterwards, both in the objects list, as well as in the viewport. Only hiding and un-hiding the "Unnamed" object fixes things back to normal.
• When "Unnamed" object is selected, and you perform Ctrl+Left click on the yellow icon in the objects list, pin icon also does not occur, but now the "Unnamed" object cannot be deselected. Again only hiding and un-hiding fixes things back to normal.
11056.206 In reply to 11056.205
Hi Fubax, thanks for reporting the bug with setting a selection filter (Ctrl+click) on the "Unnamed" entry. I can repeat it over here and I will investigate a fix.
11056.207
Hi Michael,i have questions,when you release v5?Or new beta iteration?Did you have any date for announcement? Thanks
11056.208 In reply to 11056.207
Hi blackboard,
I'm waiting on bug fixes for the ACIS library before releasing the v5 final version. Sorry I don't have a set date yet for when that will be done.
Probably have another beta release pretty soon though but I also don't have a set date for that either, sorry.
11056.209
Whenever I wanted to download latest version, it only shows: Current version: Dec-1-2023.
The file is also MoI v5 beta Dec-1-2023.zip...
Michael
Show messages:  1-9  …  130-149  150-169  170-189  190-209  210-223
