V5 beta Apr-13-2023 available now
 1-13  …  134-153  154-173  174-193  194-213  214-223
11056.174 In reply to 11056.173
Hi blackboard,
> Hi Michael,i have question about adding new ACIS core,it will be help to fastly delete fillets
> without losing the original shape before fillet?
I think so but I have not had a chance to evaluate that particular area yet.
Some ACIS functions are separated out into optional modules which I am not licensing.
> And if there is such a function, when will it be released? at the very end when the
> ACIS "press pull" function will be added?
I don't know exactly when that area will be released, but possibly not until MoI v6, the main target functions for using ACIS in the MoI v5 timeframe are fillet, chamfer, shelling, offset and face transforms.
11056.175 In reply to 11056.174
Hi Micheal, this functionality shown in the video below is also included in the license package you have for ACIS for Moi3D?
11056.176 In reply to 11056.175
Hi pafurijaz,
Nope.
11056.177
Hi Micheal, when version 5 will be released, which 3dm version of Rhinoceros also be able to open?
11056.178 In reply to 11056.177
Hi pafurijaz,
Sorry, I don't know yet.
It will open v5 .3dm files.
11056.179 In reply to 11056.178
Just wanted to write a little reminder if you would be so kind to please add the Centroid Triangulation option as a checkbox to MoI's export dialog, instead of having it hidden away in the MoI.ini file.
Here's the discussion about the subject:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=8109.1
Many thanks!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
11056.180 In reply to 11056.179
Hi Metin, one reason I have not done that yet is that I'm trying pretty hard to prevent the UI in MoI from getting bloated and complex as naturally tends to occur.
So I often hesitate and tend to be pretty conservative about accumulating too much stuff in the UI.
One thing that could help is if I could remove any control for meshing which is not really being used, perhaps "Aspect ratio limit" ?
Thanks, - Michael
11056.181 In reply to 11056.180
I understand.
In my humble opinion, Centroid Triangulation is a significant option for meshing, particularly in case of higher polygon counts. It often allows meshes to be ready for sculpting and/or deformation in Blender, ZBrush or 3D-Coat without further retopology.
I almost never use Aspect Ratio Limit, so I'd be fine with seeing that removed and having the Centroid Triangulation option instead.
I do always use all other options in the export dialog, except for Aspect Ratio Limit.
Thanks!
11056.182
Re: Deform to Sphere, Deleted Posts 11310.10 and 11311.11.
Original Question...
I'm trying to understand why in beta Version 5b...when you click Done after Deform-Flow, the Flow process just starts calculating again. In Version 4 the command stops immediately. That is confusing to me. I'm experimenting with your Bell Flat_flow.3dm file.
Is that a bug or is that just the way it works?
Wm
11056.183 In reply to 11056.182
Hi Wm,
The different behavior from v4 looks like is caused by the introduction of Groups in v5, there is some processing that happens to support groups which as a side effect triggers a final update even if there was a previous update.
I guess it's a bug since the final update for processing groups shouldn't need to be done if there are not any groups being transformed.
It's not a particularly harmful bug though, it may run the risk of messing up group handling to fiddle with it.
Support for groups involved some pretty big changes throughout the system.
11056.184 In reply to 11056.183
Michael,
Thank you for the explanation. I was just curious and didn't want this to go unnoticed
Regards,
Wm
11056.185
Hi,i think i found bug,if i fillet acis tube,he do wrong shanding
Size: 57.4 KB, Downloaded: 100 times, Dimensions: 1158x1026px
Size: 43.1 KB, Downloaded: 84 times, Dimensions: 1165x970px
11056.186 In reply to 11056.185
Hi blackboard, thanks for reporting this fillet bug, it seems to be a bug in ACIS in converting an n-sided fillet vertex blend specialized surface into a generic NURBS surface.
I'll need to send the bug in to ACIS, in the meantime I should be able to make an alternate type of conversion for these areas like in the attached version.
Thanks, - Michael
11056.187
Open large MOI file via network shared drive hang in scanning mode. I work via a QNAP fileserver as I have various machines setup for design and machining. Recently upgraded to December release BETA and I now get this scanning hang issue - was never a problem before opening large files over the network. If I copy the file to local location file opens without scanning no problem.
any thoughts
Alex
11056.188 In reply to 11056.187
Hi Alex, there hasn't been any changes in file loading for quite some time.
Did you recently change any of your network infrastructure?
I don't think there is much I can do about network access being slow, that's pretty much out of the app's control.
11056.189
Hi Michael, I rolled back MOI to V4 and no problem in opening files across network. I have 2 other slave workstations 1 with win 10 other win 11 I never updated MOI on those running v4 and files open across network no problem. On the QNAP file server I havent done any firmware upgrades on that either for quite some time. For now Ill keep working in MOIv4 - maybe some security permissions as the program is beta? not sure
11056.190 In reply to 11056.189
Hi Alex, can you please send me an e-mail at moi@moi3d.com ? I'll prepare some test builds of earlier v5 versions if you are willing to test them out to hopefully pinpoint what caused the change in network behavior.
11056.191
I only started using any of the V5 betas in the last few weeks. Running the Dec-1-2023 beta right now, I notice a considerable lag navigating the viewports and the UI in general. The exact same file will feel more sluggisch in V5 compared to V4. I don't know what changed to cause this (perhaps the grouping functionality?). Also, I can hear the fans of my Macbook Pro spin up when working, which it never did on V4.
Any thoughts?
11056.192 In reply to 11056.191
Hi Fabien, can you please e-mail me (moi@moi3d.com) your moi.ini file?
Also is it an Intel or ARM machine?
Thanks, - Michael
11056.193
Same thing with Linux WineHQ, I can't use version 5 and I've tried everything, we've already exchanged messages but none of this has ever resolved anything.
Show messages:  1-13  …  114-133  134-153  154-173  174-193  194-213  214-223
