V5 beta Apr-13-2023 available now
 1  …  122-141  142-161  162-181  182-201  202-221  222-223
11056.162 In reply to 11056.161
Hello
Thank you Micheal
I used to do some CARS in blender , but working inside moi is just waaaaaaaaay better for me than other software
Importing subd is also a good idea for better precision in some operations like boolean
Thank you again
have a good night
11056.163
Hello Michael,
Will Export to 3MF be available in V5?
It sure would be helpful for additive creators like me. Thanks!
All my best-
MOI since V1
11056.164 In reply to 11056.163
Hello,
Probably not for v5 but I have it on my radar to look into.
11056.165 In reply to 11056.161
Hi!Michael,I quite agreeMoI is not really focused on that type of "fill things in patch by patch" style of NURBS modeling because it's a rather advanced and finicky area.But usually when you want things to be continuous it is better to make one large extended surface instead of separate pieces. Either that or the other alternative is to do that type of model as a sub-d model and convert it into continuous surfaces using the Subd import converter.It is very necessary for beginners to supplement the problem, can you do a tutorial or recommended tutorial on expanding the surface or sub-d method, I find many on the Internet are fast forward, novice completely unable to understand and learn this kind of supplement skills.I think moi is very good, mainly the problem of multilateral complement and surface continuity, which has been bothering me.
11056.166 In reply to 11056.165
Hi c3g,
There is a good introduction video to how sub-d works here:
https://www.youtube.com/watch?v=ckOTl2GcS-E
11056.167 In reply to 11056.1
Hi Michael.
Any news on the release date of V5?
11056.168 In reply to 11056.167
Hi cyanayc,
Maybe right near the end of the year, not 100% sure though.
11056.169
Is there a chance to update 3dm importer in Moi ?
I'm getting more and more *.3dm v7 file formats from Rhino and i can't open them in Moi which is still stuck at v5 of 3dm file format :(.
Lewis
www.ram-studio.hr
Skype - lewis3d
11056.170 In reply to 11056.169
Hi Lewis, I'm sorry but it will be pretty difficult to update to a new .3dm importer with every new release of Rhino.
Currently it's not planned. But I have made a free conversion utility that can convert Rhino v6 or v7 .3dm files into a v5 .3dm file that can then be opened with MoI.
It's available here:
http://moi3d.com/resources#Rhino6/7_3DM_file_format_to_Rhino5_3DM_file_format_(MOI3D_compatible)_converter
11056.171
Thanks for quick reply.
I just tried this converter and I have 2 problems with it.
1. it just dumps _v5 file, no save as or progress bar (weird but ok i can live with that).
2. It's not loaded completely (I'm trying to convert chair 3d model and i got only frame but soft cushioning is not visible in Moi after conversion). So basically moi is not opening it correctly after conversion or conversion is bad.
I can send you model if you wish to test ?
EDITED: 19 Dec 2023 by LEWIS3D
11056.172 In reply to 11056.171
Hi Lewis,
Right, that's because it takes a lot of work to make functionality like progress bars, this is just a bare bones utility program that isn't focused on having any UI.
Most likely the soft cushioning is some kind of object type that MoI does not support like a polygon mesh object.
Moi only reads NURBS and annotation type objects from .3dm files, not every kind of thing that Rhino can store in them.
Sure you can e-mail it to me at moi@moi3d.com, you may need to use a file sharing service if it's very large.
But it's very likely that it's polygon mesh data that MoI is not designed to work on.
11056.173
Hi Michael,i have question about adding new ACIS core,it will be help to fastly delete fillets without losing the original shape before fillet?
And if there is such a function, when will it be released? at the very end when the ACIS "press pull" function will be added?
11056.174 In reply to 11056.173
Hi blackboard,
I think so but I have not had a chance to evaluate that particular area yet.
Some ACIS functions are separated out into optional modules which I am not licensing.
I don't know exactly when that area will be released, but possibly not until MoI v6, the main target functions for using ACIS in the MoI v5 timeframe are fillet, chamfer, shelling, offset and face transforms.
11056.175 In reply to 11056.174
Hi Micheal, this functionality shown in the video below is also included in the license package you have for ACIS for Moi3D?
11056.176 In reply to 11056.175
Hi pafurijaz,
Nope.
11056.177
Hi Micheal, when version 5 will be released, which 3dm version of Rhinoceros also be able to open?
11056.178 In reply to 11056.177
Hi pafurijaz,
Sorry, I don't know yet.
It will open v5 .3dm files.
11056.179 In reply to 11056.178
Just wanted to write a little reminder if you would be so kind to please add the Centroid Triangulation option as a checkbox to MoI's export dialog, instead of having it hidden away in the MoI.ini file.
Here's the discussion about the subject:
https://moi3d.com/forum/messages.php?webtag=MOI&msg=8109.1
Many thanks!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
11056.180 In reply to 11056.179
Hi Metin, one reason I have not done that yet is that I'm trying pretty hard to prevent the UI in MoI from getting bloated and complex as naturally tends to occur.
So I often hesitate and tend to be pretty conservative about accumulating too much stuff in the UI.
One thing that could help is if I could remove any control for meshing which is not really being used, perhaps "Aspect ratio limit" ?
Thanks, - Michael
11056.181 In reply to 11056.180
I understand.
In my humble opinion, Centroid Triangulation is a significant option for meshing, particularly in case of higher polygon counts. It often allows meshes to be ready for sculpting and/or deformation in Blender, ZBrush or 3D-Coat without further retopology.
I almost never use Aspect Ratio Limit, so I'd be fine with seeing that removed and having the Centroid Triangulation option instead.
I do always use all other options in the export dialog, except for Aspect Ratio Limit.
Thanks!
Show messages:  1  …  102-121  122-141  142-161  162-181  182-201  202-221  222-223
