V5 beta Apr-13-2023 available now
 1-10  …  111-130  131-150  151-170  171-190  191-210  211-223
11056.151 In reply to 11056.150
Hi Lewis,
> So if there would be live/proceed or some sort of button on that panel which then start process
> instead starting as soon as it's opened ?
Sorry, no MoI's UI is specifically designed to not need an update button like that, it just automatically cancels the current calculation and starts an updated one whenever any meshing parameters are modified.
One thing you could do is to select just one object and do File > Export, that will pop up the meshing options dialog on a low computation load and once you have the settings how you want cancel that export and the same settings will be used on your next full export.
- MIchael
11056.152 In reply to 11056.151
Yeah, I've tried doing that too, but GUI feedback is still very, very slow, it takes like 15-20 seconds to TAB to another filed with this mesh :(.
So that's why i hoped i could "tune in settings on just one piece" and then "live" all other layers and hit export, but it always meshes firs tin GUI = 5 minutes wait for it to finish, and then it saves file (Exported OBJ was 12 GB ).
Thanks anyway.
Lewis
www.ram-studio.hr
Skype - lewis3d
11056.153 In reply to 11056.152
Hi Lewis, what are your machine specs?
You mean exporting just one single object is taking that long?
If this particular model is made up only of one individual extremely complex object then draw in a sphere or a box and select it and use File > Export on that to alter settings.
Yes you can do that, select the just one piece and use File > Export, not File > "Save As".
Export will mesh only the selected objects while Save As does everything regardless of selection.
EDITED: 14 Sep 2023 by MICHAEL GIBSON
11056.154 In reply to 11056.153
My machine is Win10 64bit, AMD Threadripper PRO 3955WX, 256GB RAM, 2*RTX 4090 + RTX 3090, NVMe 1GB drive.
As for GUI slownnes, when GUI export popup window show up and then i try do drag slider it's sluggish, even typing the value is so slow that here is 15-20 sec pause between going to next input field.
I know it's because of big model but yeah that's why i hoped there could be "delayed" update button or so for those cases.
When model is not so big it's fine, GUI is responsive in those situations..
chers
Lewis
www.ram-studio.hr
Skype - lewis3d
11056.155 In reply to 11056.154
Hi Lewis, what happens if you go into moi.ini (Options > General > "Edit .ini file" button) and change:
[Mesh Export]
ThreadLimit=8
Is the GUI on a heavy export less hiccupy then?
If yes then that probably indicates that I can do some (tricky) work to improve the GUI response when a whole lot of calculation threads are being used.
11056.156 In reply to 11056.155
Hmm i tried that and yes maybe GUI is a bit more responsive (nothing major) now but now overall exporting process is slower now since it uses only 30-31% of my CPU strenght/cores (my CPU is 16c/32t).
It wasn't hitting 100% before either but it was 50-70% so faster export overall :).
thanks for idea.
Lewis
www.ram-studio.hr
Skype - lewis3d
11056.157 In reply to 11056.156
Hi Lewis, thanks for testing that. Does your model happen to have some large individual surfaces in it?
I think the GUI stutters are probably when it's blocking waiting for the current in progress meshing to finish being canceled. I think I should be able to improve this, I will try.
11056.158 In reply to 11056.157
Graphics driver?
11056.159
Thanks Michael,
every optimization/speed-up is always welcome :).
Lewis
www.ram-studio.hr
Skype - lewis3d
11056.160
Hello
I hope you all doing good
will be there some surface continuity feature , like between network surfaces ( patches ) in the new v5 of moi (like in rhino) ( controlling continuity when patching with already existing edge )
its a really helpful when surfacing some large complex surfaces like cars
Thank you
have a good day all
11056.161 In reply to 11056.160
Hi prince, sorry no there isn't any new surfacing with continuity functions expected for MoI v5.
MoI is not really focused on that type of "fill things in patch by patch" style of NURBS modeling because it's a rather advanced and finicky area.
You'll need to use some other CAD program for that type of surfacing.
But usually when you want things to be continuous it is better to make one large extended surface instead of separate pieces. Either that or the other alternative is to do that type of model as a sub-d model and convert it into continuous surfaces using the Subd import converter.
11056.162 In reply to 11056.161
Hello
Thank you Micheal
I used to do some CARS in blender , but working inside moi is just waaaaaaaaay better for me than other software
Importing subd is also a good idea for better precision in some operations like boolean
Thank you again
have a good night
11056.163
Hello Michael,
Will Export to 3MF be available in V5?
It sure would be helpful for additive creators like me. Thanks!
All my best-
MOI since V1
11056.164 In reply to 11056.163
Hello,
Probably not for v5 but I have it on my radar to look into.
11056.165 In reply to 11056.161
Hi!Michael,I quite agreeMoI is not really focused on that type of "fill things in patch by patch" style of NURBS modeling because it's a rather advanced and finicky area.But usually when you want things to be continuous it is better to make one large extended surface instead of separate pieces. Either that or the other alternative is to do that type of model as a sub-d model and convert it into continuous surfaces using the Subd import converter.It is very necessary for beginners to supplement the problem, can you do a tutorial or recommended tutorial on expanding the surface or sub-d method, I find many on the Internet are fast forward, novice completely unable to understand and learn this kind of supplement skills.I think moi is very good, mainly the problem of multilateral complement and surface continuity, which has been bothering me.
11056.166 In reply to 11056.165
Hi c3g,
There is a good introduction video to how sub-d works here:
https://www.youtube.com/watch?v=ckOTl2GcS-E
11056.167 In reply to 11056.1
Hi Michael.
Any news on the release date of V5?
11056.168 In reply to 11056.167
Hi cyanayc,
Maybe right near the end of the year, not 100% sure though.
11056.169
Is there a chance to update 3dm importer in Moi ?
I'm getting more and more *.3dm v7 file formats from Rhino and i can't open them in Moi which is still stuck at v5 of 3dm file format :(.
Lewis
www.ram-studio.hr
Skype - lewis3d
11056.170 In reply to 11056.169
Hi Lewis, I'm sorry but it will be pretty difficult to update to a new .3dm importer with every new release of Rhino.
Currently it's not planned. But I have made a free conversion utility that can convert Rhino v6 or v7 .3dm files into a v5 .3dm file that can then be opened with MoI.
It's available here:
http://moi3d.com/resources#Rhino6/7_3DM_file_format_to_Rhino5_3DM_file_format_(MOI3D_compatible)_converter
Show messages:  1-10  …  91-110  111-130  131-150  151-170  171-190  191-210  211-223
