V5 beta Apr-13-2023 available now
 1-7  …  88-107  108-127  128-147  148-167  168-187  …  208-223
11056.128 In reply to 11056.1
Hello Michael!
How's it going? Hope everything's alright.
Have you some news about the V5 development?
Compared to V4 (that was a major rewrite at time) what are the advantages of this new upcoming V5?
And, last but not least, are there any current advantages to using the V5 beta compared to the official V4?
(I mean modelling speed, stability, better performance with Apple Silicon, etc...)
Thanks and have a good day.
11056.129 In reply to 11056.128
Hi Marco, the biggest new things for v5 are - improved fillets using the ACIS library, Groups, SVG format, UI theme editor with dark mode, and native arm64 build for Apple Silicon.
Well, the current v5 beta has all the above stuff in it which isn't in v4.
There is a collection of all the v5 beta release notes here:
https://moi3d.com/wiki/V5Beta
11056.130 In reply to 11056.129
Thanks Michael!
Very interesting the specific build for Apple Silicon. So, in the V5 build, are you directly calling Metal APIs?
I'm asking you about Apple Silicon because, for example, I would like to know if now I can set the viewport display angle to 5 instead of the standard 10, without getting slowdowns, thanks to Metal API and M1/M2 GPUs.
Please let me know.
11056.131 In reply to 11056.130
Hi Marco,
Using Metal APIs is a separate thing from arm64/Apple Silicon. But Moi v5 will also support rendering using the Metal API, it should be fully functional with the next v5 beta release.
In general I've found that the Metal API is somewhat slower than OpenGL so I don't expect that you would see any improvement in that area.
Despite its name and marketing Metal is a more "managed" display pipeline, there isn't any way set up to use the CPU and GPU in parallel for constructing a single frame in Metal unlike OpenGL. Basically it lacks any mechanism for dynamic vertex buffers.
11056.132 In reply to 11056.131
Thanks for these info :)
But...this sounds me a bit strange.
As far as I know, OpenGL hasn't been supported (natively) on Apple computers, for years now.
All the GOU development has shifted to Apple Silicon and Metal API.
How is it possible that Metal can't deliver as much, if not more, as power compared to the OLD OpenGL?
This sounds really strange...
11056.133 In reply to 11056.132
Hi Marco,
That's incorrect. OpenGL.framework is implemented in native arm64 code on all Apple Silicon operating systems so far at least.
It's because in kind of typical Apple fashion they've prioritized API "elegance" over functionality.
The way the Metal API is designed, you assemble a full list of instructions and then submit that entire instruction set to the GPU which then executes it on the GPU.
To get CPU/GPU parallel processing they advocate using a triple buffering mechanism which works fine for a game that is constantly animating in a render loop but MoI is rather different than a game. Instead of trying to have a constant FPS on a preplanned scene MoI is more focused on generating just the current frame using both the CPU and GPU in parallel. Metal is not able to use both CPU and GPU in parallel within the scope of a single frame unlike OpenGL or Direct3D using dynamic vertex buffers.
Basically there is a thing in OpenGL and Direct3D called "dynamic vertex buffers" which allows data to be streamed from the CPU to the GPU while the current frame is being generated. Metal does not have this function.
11056.134 In reply to 11056.133
Thanks for this detailed explanation :)
OK. Got it.
Have a nice day.
11056.135 In reply to 11056.129
Hello Michael.
Where I can read something about the new (or improved) "Groups" functionality of the V5 beta?
11056.136 In reply to 11056.135
Hi Marco,
There is some information in the v5 beta release notes which are gathered here:
11056.137
Hello Michael,how development going?We can see full v5 version of moi in 2023?
11056.138 In reply to 11056.137
Hi blackboard,
It's been slow recently, I've been working on some tricky bugs.
I hope so but I don't know for sure.
11056.139 In reply to 11056.138
Ok,thanks for answer we will wait
11056.140 In reply to 11056.138
Since my Trial v4 version has expired for some time, the question is when can we expect a 5 full version and at what price.
I don't want to buy the 4 version first to try the updates because I only use Moi for my hobby and for fun (I'm retired).
Greetings from Hamburg
Pieter
EDITED: 4 Aug 2023 by PIETER
11056.141 In reply to 11056.140
Hi Pieter, I'm expecting the price for v5 will remain the same as v4. I'm not sure yet when v5 will be released, I hope sometime before the end of the year though.
11056.142
Hi Michael
is it possible to select a point, a line or a surface when extruding ?
( it works with origin point )
EDITED: 9 Aug 2023 by CHRI
Size: 126.9 KB, Downloaded: 95 times, Dimensions: 294x273px
Size: 59.6 KB, Downloaded: 116 times, Dimensions: 490x306px
11056.143 In reply to 11056.142
Hi christian, currently there are not snaps available on the same object that is itself being manipulated. That's because of some problems that can happen with things kind of getting stuck on themselves.
I'd like to revisit that, but for now you can place a point object (Draw curve > More > Point) where you want to snap before doing the extrude.
11056.144 In reply to 11056.143
Very clear Michael
Thanks for your quick response.
Christian
11056.145
Not sure if this event has been reviewed:
Changing image properties with proportions sizes off, the image will revert back to original ratio when dragging the anchor size.
imgbox
11056.146 In reply to 11056.145
Hi wayne,
Yes, dragging always uses the image's inherent aspect ratio. If you want to change the aspect ratio permanently you can edit the image in an image processing program to your desired new size.
11056.147 In reply to 11056.146
Thank you!
Wayne
Show messages:  1-7  …  68-87  88-107  108-127  128-147  148-167  168-187  188-207  208-223
