V5 beta Apr-13-2023 available now
 1-15  …  76-95  96-115  116-135  136-155  156-175  …  216-223
11056.116 In reply to 11056.115
Hi Martin, if you reverse the direction of the picked points that for the axis that will also reverse the direction of the revolve.
So like currently you're picking the start of the axis at the center point and then the 2nd point for it upwards along the z axis.
Instead pick the 2nd point downwards on the z axis to reverse it.
It would be a good idea if it did support a negative angle though, I have put that on my list to look at.
Message 11056.117 deleted 20 May 2023 by PAQ
11056.118 In reply to 11056.116
Thanks Michael, reversing the rotation axis picks points does indeed do the job. If you do have time to include negative angles, then I would certainly appreciate that.
Martin.
11056.119
Hi Michael.
I've been helping out a prospective purchaser of MoI and he seems to have found a bug when revolving a closed profile. I've included a short video of the problem. If the axis of rotation is set very slightly away from the profile, then it works as expected.
Martin.
https://vimeo.com/829230291?share=copy
11056.120 In reply to 11056.119
Hi Martin,
Currently the profile to revolve can only have one coinicdent line of contact with the revolve axis.
A case like this with 2 lines in contact would need to generate a solid with a void region inside of it. Revolve doesn't know how to make that kind of result currently.
To get the desired result, you'll instead need to have 2 separate profile curves like this:
Then when those are revolved that will make 2 solids. Then boolean difference can be used with the inner solid as the cutting object to make a single solid with an internal cavity.
11056.121 In reply to 11056.120
Thanks for the explanation, Michael.
Martin.
11056.122
I've tried launching installer for this beta under WINE, but for some reason it fails - I get a blank, black window. For previous version it worked (but on the other hand I've updated the system since then.... at least I've tried running it in the same wine env).
edit: after some fiddling and switching to Wine 8 I was able to start the installer successfully. I've got the same problem with MoI4 installer, which previously worked correctly - so it's not MoI thing, but rather my configuration, WINE / Linux thing. On the positive note - after installing it seems to work beautifully , so I should be able to do some minor cad work when only my laptop is available.
EDITED: 2 Jun 2023 by PRZEMAS
11056.123
Hello Michael,Do you already have a date for an approximate release of the update?
11056.124 In reply to 11056.123
Hi blackboard,
Sorry no not yet.
11056.125
I really want to create file new icons for commands in the interface, the most and naturally arising from this SVG icons.
The question arises, is it possible to use moi3d svg as icons
11056.126 In reply to 11056.125
I believe that you must converter them in PNG images...
11056.127 In reply to 11056.125
Hi blackboard, no the moi3d interface is not able to use .svg for icons directly, it is designed to use PNG images for icons.
You will need to convert your .svg into a 64x64 pixel PNG image and use the PNG.
11056.128 In reply to 11056.1
Hello Michael!
How's it going? Hope everything's alright.
Have you some news about the V5 development?
Compared to V4 (that was a major rewrite at time) what are the advantages of this new upcoming V5?
And, last but not least, are there any current advantages to using the V5 beta compared to the official V4?
(I mean modelling speed, stability, better performance with Apple Silicon, etc...)
Thanks and have a good day.
11056.129 In reply to 11056.128
Hi Marco, the biggest new things for v5 are - improved fillets using the ACIS library, Groups, SVG format, UI theme editor with dark mode, and native arm64 build for Apple Silicon.
Well, the current v5 beta has all the above stuff in it which isn't in v4.
There is a collection of all the v5 beta release notes here:
https://moi3d.com/wiki/V5Beta
11056.130 In reply to 11056.129
Thanks Michael!
Very interesting the specific build for Apple Silicon. So, in the V5 build, are you directly calling Metal APIs?
I'm asking you about Apple Silicon because, for example, I would like to know if now I can set the viewport display angle to 5 instead of the standard 10, without getting slowdowns, thanks to Metal API and M1/M2 GPUs.
Please let me know.
11056.131 In reply to 11056.130
Hi Marco,
Using Metal APIs is a separate thing from arm64/Apple Silicon. But Moi v5 will also support rendering using the Metal API, it should be fully functional with the next v5 beta release.
In general I've found that the Metal API is somewhat slower than OpenGL so I don't expect that you would see any improvement in that area.
Despite its name and marketing Metal is a more "managed" display pipeline, there isn't any way set up to use the CPU and GPU in parallel for constructing a single frame in Metal unlike OpenGL. Basically it lacks any mechanism for dynamic vertex buffers.
11056.132 In reply to 11056.131
Thanks for these info :)
But...this sounds me a bit strange.
As far as I know, OpenGL hasn't been supported (natively) on Apple computers, for years now.
All the GOU development has shifted to Apple Silicon and Metal API.
How is it possible that Metal can't deliver as much, if not more, as power compared to the OLD OpenGL?
This sounds really strange...
11056.133 In reply to 11056.132
Hi Marco,
That's incorrect. OpenGL.framework is implemented in native arm64 code on all Apple Silicon operating systems so far at least.
It's because in kind of typical Apple fashion they've prioritized API "elegance" over functionality.
The way the Metal API is designed, you assemble a full list of instructions and then submit that entire instruction set to the GPU which then executes it on the GPU.
To get CPU/GPU parallel processing they advocate using a triple buffering mechanism which works fine for a game that is constantly animating in a render loop but MoI is rather different than a game. Instead of trying to have a constant FPS on a preplanned scene MoI is more focused on generating just the current frame using both the CPU and GPU in parallel. Metal is not able to use both CPU and GPU in parallel within the scope of a single frame unlike OpenGL or Direct3D using dynamic vertex buffers.
Basically there is a thing in OpenGL and Direct3D called "dynamic vertex buffers" which allows data to be streamed from the CPU to the GPU while the current frame is being generated. Metal does not have this function.
11056.134 In reply to 11056.133
Thanks for this detailed explanation :)
OK. Got it.
Have a nice day.
11056.135 In reply to 11056.129
Hello Michael.
Where I can read something about the new (or improved) "Groups" functionality of the V5 beta?
Show messages:  1-15  …  56-75  76-95  96-115  116-135  136-155  156-175  176-195  …  216-223
