> I have noticed that the two areas of the two items do not match
Well the surface area of your cone is: 503.22 and the surface area of your flattened one is 503.35 . So they are close to matching.
What is your construction process?
If you are copying a numeric length somewhere maybe you need to temporarily increase the number of decimal places that will be shown under Options > General > "Decimal display" to improve the accuracy.
> I followed Pilou's video but I must have made a little mistake
Does Pilou's steps involve copying a length value and using it somewhere else?
If so then before you do that step try setting Options > Genreal > "Decimal display" to the maximum 7 decimal places (1.0000000) so that you'll have more precision in your result.
