Stretches the cone
All  1-3  4-14
An easy process :)
Take the edge of the cone
Copy somewhere - Oriente / Line-line/none on the XY plane
Ask détails of the base cone circular length : copy to the ClippBoard
Arc Circle Center on the extremity segment
Copy the clippBoard inside box length of the arc circle
Close to the edges
Plane
Surface Cone = 1260.781055 (don't forget to kill the base surface!!!
Surface simulated "unwraped" = 1260.781248 not so bad!
Will be the same for an horizontal truncated cone - just 2 arcs circles
the trick is to ask the details! :)
The asked detail!
EDITED: 14 Apr 2023 by PILOU
Same technic
Make like the cone above and kill the top base circular...with the new arc and edge...
Not yet moment of inspiration for an inclined truncated one! :)
11054.6 In reply to 11054.5
Hi guys, I tried both the script and making it by hand but I can't, I'm sure I'm wrong in something :(
11054.7 In reply to 11054.6
Hi Tony,
The lengths of your circles seem to match up ok, it looks like you made it ok. What is it that isn't right?
11054.8 In reply to 11054.7
Hi Michael, I have noticed that the two areas of the two items do not match
11054.9 In reply to 11054.8
Hi Tony,
Well the surface area of your cone is: 503.22 and the surface area of your flattened one is 503.35 . So they are close to matching.
What is your construction process?
If you are copying a numeric length somewhere maybe you need to temporarily increase the number of decimal places that will be shown under Options > General > "Decimal display" to improve the accuracy.
11054.10 In reply to 11054.8
Hi Tony77,
Is this what you want?
-Psygorn
11054.11 In reply to 11054.9
I followed Pilou's video but I must have made a little mistake
11054.12 In reply to 11054.11
Hi Tony,
Does Pilou's steps involve copying a length value and using it somewhere else?
If so then before you do that step try setting Options > Genreal > "Decimal display" to the maximum 7 decimal places (1.0000000) so that you'll have more precision in your result.
11054.13 In reply to 11054.10
My method gives 503,2224539
Original cone is 503,2206188
best of Psygorn is 503,221746 so he wins by 0,000007! :)
11054.14 In reply to 11054.13
Ok Michael I will follow your advice ;)
Show messages: All  1-3  4-14
