Changing Dim Arc inplace
All
1-8
9-12
RayCAD1962 (RAYCAD003)
13 Apr 2023 (9 of 12)
11052.9
In reply to
11052.8
@Psygorn (DRILLBIT)
Thank you so much for your generosity for what I asked you gave me your solution.
I don't have words to say but THANK YOU so much. You are a good teacher indeed.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
13 Apr 2023 (10 of 12)
11052.10
Where it's said on the first post that the 2 Arcs circles must be tangent ? :)
Without more infos...there are an infinite number of solutions! :)
EDITED: 13 Apr 2023 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Psygorn (DRILLBIT)
13 Apr 2023 (11 of 12)
11052.11
In reply to
11052.9
Hi RayCAD1962,
Do not mention it :-) I just shared with you what I knew.
However, as PILOU says, you should be more specific with constraints you want. Otherwise there would be number of possibilities (sometimes infinite)
-Psygorn
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
13 Apr 2023 (12 of 12)
11052.12
In reply to
11052.11
@Psygorn (DRILLBIT)
@Frenchy Pilou (PILOU)
I like to share this YouTube video from where I so these changing of dimensions with easy method that I like to see it in 3Dmoi if it is possible.
Follow the video and you will see what I am talking about especially when changing the values of each arc and lines too.
Your method is helpful but this is more easy to be used when you need it.
Video link:
https://www.youtube.com/watch?v=xu8iiDUZhFQ
Hope you understand what I am looking for.
Thanks again both of you.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-8
9-12
