Best way to accomplish wrap around shapes
All  1-7  8-11
11051.8
Good day.
Thanks!
I did manage to make something in the direction that I want.
I guess to flow the shapes all around is not easy to do.
Another question pic attached.
In order to get the triangles into a certain shape I needed trim (I do not know if this is the best way to do this)
Is there a better and more efficient way to do this?
Size: 88.2 KB, Downloaded: 36 times, Dimensions: 482x418px
Size: 67.3 KB, Downloaded: 52 times, Dimensions: 624x773px
11051.9 In reply to 11051.8
Hi Matadem,
Yes, Boolean intersection can be more efficient because it will automatically figure out which pieces are contained inside the outline. So you won't have to pick which pieces to discard like you do with Trim.
Select the pieces you want to cut, then run Construct > Boolean > Isect (short for Intersection), then select your closed outline curve:
11051.10
Got it.
Tnx!
11051.11 In reply to 11051.10
What a great thread you started!
Nice!
Tom
Show messages: All  1-7  8-11
