Expanding tool panels
All  1-3  4-5
11050.4 In reply to 11050.1
> Be default some of these are minimised to save space. However, on
> larger monitors they can all be expanded.
Hi Mark, if some are minimized on startup it probably means the regular window size is small.
You can fix that by unmaximizing the window with the control in the far upper right corner, then size the now unmaximized MoI window so it is large on your screen, then close MoI so that window location will be saved.
Then restart MoI and you can now maximize it and leave it that way.
Basically what happens is that during program startup MoI will initially get the unmaximized window size set on it before it gets maximized and if the unmaximized size is small that will collapse some of the palettes.
The method that Pilou writes about above is a script that will modify the UI so that all the tool palettes are individual pieces instead of there being multiple ones on the same row. The post for that one is here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9439.3
11050.5 In reply to 11050.4
Thanks all. :-)
M
Show messages: All  1-3  4-5
