Mobile Phone Charger
All  1  2-10
1105.2 In reply to 1105.1
Looks good Lish!
Hi Lish
Cool object added to the special thread Gallery :)
but seems you must make something like 50% reduction for avoid Aliasing ;)
1105.4 In reply to 1105.3
- but seems you must make something like 50% reduction for avoid Aliasing ;)
Hi Pilou, sorry,,,,could you explain to me about "50% reduction for avoid Aliasing" ?
Do you mean for the sharp edge or ... ?
Regards,
Lish
1105.5 In reply to 1105.4
Just for the visual aspect and reduct the "stairs effect" :) No more ;)
1105.6 In reply to 1105.5
Hi Pilou & All Forum member...
So, could you give me some tips to reduce stairs effect ?
Regards,
Lish
1105.7 In reply to 1105.6
I guess, Pilou just meant you could scale the image down (e.g. in Photoshop) before sending it here :)
Message 1105.8 deleted 10 Nov 2007 by KNIGHTXOR
1105.9
Change mesh angle down to a lower number in the settings, it will slow down frame rate, but make it look smoother.
1105.10
Hi Lish. It seems you have at least one surface which is folding back onto itself. Perhaps it will join up as a closed polysurface, but this will be a problem if you try to run a fillet or chamfer. Also it may create very heavy mesh when you export. I am guessing you made that surface using Network or Sweep with 2 rails? This can create problems when making a 3 sided surface . I would suggest you create a new 4-sided surface which extends beyond those edges and then trim away the excess. That is best way to avoid folding near a singularity...
jonah
Show messages: All  1  2-10
