fillet method that makes aligned tangent edges
All  1-8  9-14
11045.9 In reply to 11045.8
Thanks for confirming that there aren't any CAD programs that define fillet width in this way. That's sort of what I figured and was not suggesting that MoI be changed to do it like this. Just thought someone here on the forum might have a trick to avoid these troublesome mismatches when making appearance models. For most stuff I have to stick with constant radius fillets since anything involving variable radii is troublesome to machine.
Also, thanks for the peak into how filleting works. That's pretty interesting about how the rail is made.
- Peer
11045.10 In reply to 11045.7
Hi Peer.
I do it this way...
image host
11045.11 In reply to 11045.10
Hi WN,
Your method is interesting. what tool do you use to make your video?
- Zooen
Everything that is imagined and invented is true, you can be perfectly sure of it.
11045.12 In reply to 11045.11
Hi Zooen.
"what tool do you use to make your video?"
https://getsharex.com/
11045.13 In reply to 11045.10
Thanks WN! That's a clever method you came up with.
- Peer
11045.14 In reply to 11045.10
Very tricky!
Show messages: All  1-8  9-14
