V5 beta Apr-8-2023 available now
 1  2-21  22-41
11043.2 In reply to 11043.1
Seems no need to change something in the FrenchString.txt! ;)
11043.3 In reply to 11043.2
Thank you Michael !
11043.4
Hello Michael,
So ACIS fillet seems to have some sort of 'auto add tangent edges' feature, but ... no all the time.
In this example I'm trying to fillet this cube, and depending what edge I select, the result is a little bit unpredictable. The red dot represents what initial edge I can click to fillet the whole loop at once. In the fist one, any of the 3 edges is fine: The second version, only one of the straight edges will process the loop at once. Last 2 models, there is no auto-loop at all.
I'm starting to really like this auto add tangent feature, but off course use should also have the choice ... is it something you planning to add at some point ?
11043.5 In reply to 11043.4
HI PaQ, that seems to be something that ACIS is doing automatically and I'm not seeing how I can control it. I'll need to ask their tech support for info.
11043.6 In reply to 11043.5
Oki!
11043.7 In reply to 11043.1
I see real time Fillet Sizing in the Point Picker for ACIS!!!
Nice!
And so it begins!!
11043.8 In reply to 11043.7
Last beta version 8 avril 2023
Indeed but also a little glitch (not visual effect display but real error of result)
here the file3 dm is this the same for you ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/kub05.3dm
Wanted this edge filleting...(reproductible glitch)
Will work in Solid++ in making a boolean Diff with the solid and the bad face result! 3° radius
Same Booelan seems impossible with Acis who gives also an error but not the same! :) Also 3° radius
EDITED: 9 Apr 2023 by PILOU
11043.9
Hello,thanks for new update.what will come out next? will moi3d have a pull/push function like in fusion or similar like in plasticity. When will the next beta release be?
11043.10 In reply to 11043.8
Hi Pilou, thanks for the bug report.
It's a bug in the display mesher, so it actually is just a visual effect display bug.
If you save the glitched result to a .3dm file and reload it, is the glitch then gone?
11043.11 In reply to 11043.10
Alas no same result!
In Solid++ or Acis !
But if i draw another box different than the above that works normally!
I was unlucky to input a box with the false dimensions! :)
Very very curious! :D
11043.13 In reply to 11043.11
Hi Pilou, here are the steps I'm following.
Step 1 - load your file kub05.3dm using the Apr-8-2023 v5 beta.
Looks like this:
Then i selected the edge you indicated:
And then I ran the Fillet command and put in radius = 3, I get the glitch that you saw:
After the fillet command has been completed if I now save to a .3dm file and reload it, the glitch is gone. Looks like this:
Do you see different results with these same steps?
Crossing post
With a box 3 x 4 x 5
11043.15 In reply to 11043.14
And if you save the glitched result to a .3dm file and reload it?
Yes when i reload or import the glitch disapears for my box 3 4 5
or for my previous one! :)
Good luck for find the the display bug! :)
11043.17 In reply to 11043.9
Hi blackboard,
Next there will probably still be more fixes for the fillet integration.
Yes, that's the "Direct Modeling" functionality that I was mentioning earlier.
There is some push/pull like functionality already working though, if you select a face object then you can use the Extrude command to do a push/pull like action where it automatically booleans the extrusion with the main body.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6790.3
There will probably be new bug fix releases every 1 to 2 weeks while tuning the ACIS integration.
11043.18 In reply to 11043.16
So that's an easy fix for the moment for this display bug. But I will see about fixing it up so that isn't necessary.
Thanks, - Michael
11043.19 In reply to 11043.18
I tried Pilou's example, get the same artifact.
However: If you right click (the command repeats), just click the object, then DONE and the artifact is gone...
11043.20 In reply to 11043.19
cool trick before the fix!
11043.21 In reply to 11043.17
Nice,i very glad to see how you add improvement.
I have one more question,there are forecasts when you will be able to add direct modeling?
Show messages:  1  2-21  22-41
