Easy way to convert lines to dashed or dotted?
All  1-7  8-14
11037.8 In reply to 11037.7
Hi Matadem, I'm sorry I'm not sure if you are set up ok now or still need help.
> How ever the same file imported into Moi I get the next attached pic (the same I get in vcarve)
MoI does not support setting line style property for dahsed/dotted/solid type lines yet.
another way could to use ReconstructCurve script to construct a polyline
On this Polyline, you use Separate
Next You use PatternSelection
Right or wrong ?
Just trying to make some sense of dashed lines:
Found some dash methods here:
https://threejs.org/docs/#api/en/materials/LineDashedMaterial.scale
Stroke = the Line segment portion of a Dash.
Dash = Stroke plus Gap.
User adjustable Default values, where the size is an index of the length, to be determined:
dashSize = 3
gapSize = 1
So stroke would equal 2, and gap would equal 1.
The total number of Dashes: dashNum = 100. (Plus one final Stroke?) User adjustable.
??? Scale = 1 ???
LineWidth = 1. (Just regular line segment MoI width?) (Fatlines?)
LineCap choices: butt???, round, square. Might be relevant for Fatline dashes?
(And use the previously described Flow method to transfer to curved line)
A la chainmaker script.
FatLines script works for multiple curve segments.
Suggestion, Add LineCap choices to FatLines, (Fillet)
Here is a very good essay on "Data Visualization Using Lines, Dashes, Dots & Arrows".
https://medium.com/javascript-fanboi/2022-054-data-visualization-using-lines-262f2051b1b2
It is for Canvas, but the ideas could be applied to NURBS, IMHO.
lineDashOffset property
Picture examples are given of LineCap properties Round, Square, and Butt.
EDITED: 2 Apr 2023 by BEMFARMER
11037.12
I made a simple node to automate converting curves/lines to dashed lines.
open Nodeeditor => load attached node => select lines => update "Selected" node => run
11037.13 In reply to 11037.12
Here's another node method
11037.14
In the end I trimmed the lines to get things going...time consuming...
I am going to try the node editor as I did not use it yet for anything...
Attached a pic for the way to change it in Pepkura...fast...Change from solid line to dashed and or options.
Tnx!
Size: 55 KB, Downloaded: 139 times, Dimensions: 543x414px
Show messages: All  1-7  8-14
