V5 beta Mar-28-2023 available now - ACIS fillets
 1-3  …  44-63  64-83  84-103  104-106
11034.84 In reply to 11034.82
Hi pafurijaz,
> I did a test, on a model, I'll do some tests during these days and then I'll share them, however on
> Linux the performance has improved a lot, I don't understand if this depends on something else
> but now everything is super smooth!
That's great! There has been a couple of tweaks to avoid certain texture formats that did not seem to be supported well on Linux.
I would not have thought that it would make such a big difference but it must have been triggering some slow path.
11034.85 In reply to 11034.83
>There is also an EDU upgrade version as well.
Thanks for information.
11034.86
Really nice update Michael!
David
11034.87
Great stuff, Michael, thanks for all the hard work.
I don't use MOI often (I'm mainly polygonal modeller/render guy) but when i do need to use it i always enjoy using/discovering new stuff.
Lewis
www.ram-studio.hr
Skype - lewis3d
11034.88
Hello,can people who bought a v4 octane license get access to v5 beta? the problem is that they don't have a license key but they do have a license, what should these people do in this situation?
11034.89 In reply to 11034.77
Hello,
I thought booleans were also involved a lot for filleting that they will be higher on the list ( I have nothing to complain about the actual booleans tho)
Switching those to ACIS will also mean we could have some 'direct' modelling enhancement like moving the cutter solid later in the design ? Or is that an other history based mechanics ?
11034.90 In reply to 11034.88
Hi blackboard,
There will be a separate v5 beta build for octane users that will be available in their account page.
I'll get that set up for the next beta release, there will be a new release soon with a bunch of bug fixes.
11034.91 In reply to 11034.90
it's for this bundle ?
https://home.otoy.com/octane2023/
11034.92 In reply to 11034.91
Yes, that one.
11034.93 In reply to 11034.89
Hi PaQ,
Right, booleans are an area that Solids++ does handle well, so there is not as much to be gained by switching them compared to filleting.
There are direct modeling functions in ACIS which should allow things like this. I don't know the exact details of how well it will work quite yet.
The direct modeling functions are not dependent on booleans being handled by ACIS.
11034.94 In reply to 11034.92
<< Yes this one
so the V4 of MOi ? Or a special one ? or a previous one ? or...
And can it works alone ? (Moi)
11034.95 In reply to 11034.94
That bundle currently includes MOI version 4. I will be making a v5 beta release for it as well, for the next v5 beta release.
11034.96 In reply to 11034.95
And these versions work as normal version ? They are "standalone" ?
11034.97 In reply to 11034.96
The only difference from the regular version is that they have a login dialog to log in to your Octane account instead of using a license key.
11034.98 In reply to 11034.97
Thanks for the Infos!
Last ...you can use the current betas as the normal ones?
11034.100 In reply to 11034.99
You can use the current betas for commercial work same as the regular version.
11034.101
Hello Michael,
First, Let me thank you for this new beta release; this is awesome! as always :-)
Second, is ACIS library used only for fillets? (sometimes when I use ACIS to do the fillets I get torn faces but MOI says the geometry is solid & when I do the fillet with Solids++ I don't get that torn face) it is not a big issue at all, I just wanted to ask you about it out of curiosity. :-)
Edit: Hello again, I think u have replied to this in reply to one of Pilou's posts by mentioning: -> It's a bug in the display mesher, so it actually is just a visual effect display bug.
I think I got my answer.
Best,
Psygorn
EDITED: 9 Apr 2023 by DRILLBIT
11034.102 In reply to 11034.101
Hi Psygorn,
Yes at the moment only for fillets, but once a few more kinks are worked out I expect to use it in some other areas as well like chamfer, shell and offset, and face editing.
Yes if it looks like the thing Pilou shows and it goes away if you save and reload the .3dm file then it's probably that same display mesher bug.
It seems that ACIS tends to create trimming boundaries that sometimes run across some kind of bug in the display mesher.
I haven't quite gotten that figured out yet,
For the time being when you run across it, just try saving it to a .3dm file and reload it back in again.
11034.103 In reply to 11034.102
Thank you for your reply :-)
I did export my mesh as a .stp file and looked it up inside 123Desig there was not any issue whatsoever :-)
Best,
Psygorn
Show messages:  1-3  …  24-43  44-63  64-83  84-103  104-106
