V5 beta Mar-28-2023 available now - ACIS fillets
 1-7  8-27  28-47  48-67  …  88-106
11034.8 In reply to 11034.6
I began to wonder if I installed the new beta properly???
If you use Window (10 or 11) and taskbar icon for MoI:
DO create a NEW taskbar ICON for new MoI5 Beta!
I have re-edited this post, and my post 6, to correct my many incorrect/inaccurate statement blunders :-).
EDITED: 2 Apr 2023 by BEMFARMER
11034.9
Nice, thanks for this new beta !
11034.10 In reply to 11034.1
You've been working hard! I'm excited about face.analyticFrame and all these other improvements.
- Peer
11034.11 In reply to 11034.5
> Minor typo in Notes: "didsabled":
Corrected, thanks!
> I suppose ACIS company charges Triple Squid Software Design a fee per user?
I'm sorry it's probably best if I don't discuss the licensing terms. But I will be absorbing the licensing cost, Moi prices will remain the same.
11034.12 In reply to 11034.6
> Regarding Theme change for the Object, Type and Style menus:
> The old bug of open menus not having Theme update has been corrected!!!
Great! Yes there were some bug fixes for this also.
> But it is necessary to create a NEW taskbar ICON for the new beta, rather than
> using the old taskbar ICON.
Sorry I'm not really understanding this part. If you want the new beta to be pinned to the taskbar after you launch it you will need to right click on it in the taskbar and choose "Pin to taskbar" on the menu that pops up.
The new beta will not automatically overwrite any previous pinned shortcuts.
> Did not observe any "crosstalk" with MoI4 menu colors, from MoI5b themes.
Yes there were some bug fixes for this as well.
Thanks, - Michael
11034.13 In reply to 11034.7
> Even this can be realized by a Boolean Diff with the error surfaces Fillet! ;)
Yes, the old filleter would try to leave fillet surfaces behind when it was not able to trim a hole for them. That's so you could have a chance at salvaging it.
But it's a lot more convenient if it just works.
Cool! (Acis) Solid++ fails
But there is a secret! ;) Rotate the cylinder before the Boolean Union!
11034.15 In reply to 11034.14
Hi Pilou, with ACIS fillets you can do it without rotating the cylinder if you do it in 2 separate chunks:
I'm not sure exactly why yet.
Maybe I need to mark the vertex at the collapsing point to not attempt to be smoothed there.
Also in some cases it can help to not try to include already smooth edges as fillet targets.
11034.16 In reply to 11034.15
Thx for the trick but not sure in this case that is so appetizing! :)
11034.17
Thanks for the new Beta Michael!
I like how you've set up the Hatch for AI export, creating hatch groups per/face and sub-groups for min & max. :)
EDITED: 2 Apr 2023 by SBEECH
Size: 548.6 KB, Downloaded: 231 times, Dimensions: 2929x1316px
11034.18 In reply to 11034.17
Thanks Dan, I hope that can be useful for getting a different illustration feel.
11034.19 In reply to 11034.18
The exported grid is fantastic, I've been wondering for some time if it was possible to export the surfaces in mesh but using the nurbs patch topology, i.e. export the grid of nurbs patches in mesh.
Another thing seem more responsive in my case with Linux!
Greetings
The ACIS fillet does not seem to apply to 2D object comprised of closed curves???
ACIS fillet applies to a Solid.
ACIS fillet seems to apply to an extruded object, even if it is not a solid.???
11034.21 In reply to 11034.20
Hi Brian, ACIS works with surfaces and solids but with curve is useless.
11034.22 In reply to 11034.20
Yes that's correct, there isn't anything different for curve filleting, the new stuff is for edge based filleting.
It can be a solid or a joined surface.
11034.23 In reply to 11034.19
Hi pafurijaz,
> The exported grid is fantastic, <...>
Do you mean the new cross hatching for 2D drawings?
I'd love to see some examples if you're using it.
There were a couple of improvements for running on Wine.
Thanks, - Michael
Solid++ fails ;)
Acis works but only one by one...does this normal ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/onebyone.3dm
11034.25
It seems there are things that the Solids++ fillet can do that the ACIS can't. Will it be sticking around?
Solids ++:
ACIS (will not calculate):
Even doing the edges separately with ACIS does not result in correct fillet.
Also not sure if you just aren't supposed to select a surface to fillet, but with ACIS it leaves a visual gap when do so:
Result:
Hi Charlie,
Could you post your file ?
It could help Michael to find the probem.
It seems the base has both all edges of your cylinder and all edges of the box.
11034.27
I thought you were done with the kernels choice !
Must've been a lot of work, can't wait to try this out.
Thanks !
Marc
Show messages:  1-7  8-27  28-47  48-67  68-87  88-106
