V5 beta Mar-28-2023 available now - ACIS fillets
 1-16  …  37-56  57-76  77-96  97-106
11034.77 In reply to 11034.76
Hi blackboard,
> Oh thanks,i don't now why if i choice dark theme my viewport color stay white as
> default,i change color and its work
That will happen if you've set a custom viewport background color in a previous version.
You can reset it to follow the theme color under Options > View > Colors > Background color: "From theme".
> I have another question do you want add full acis possibilities or only fillets?
I'm also expecting to use it for Chamfer, Shell/Offset, and what is called "Direct modeling" functions like transforming an individual face and the surrounding faces extend to meet the edited face. That should be a good spot to wrap up v5 at that point.
Over a longer period I'll probably experiment with replacing other things like booleans.
11034.78 In reply to 11034.77
Nice,how much time do you need to create version 5 the way you want?
EDITED: 6 Apr 2023 by BLACKBOARD
11034.79 In reply to 11034.77
""""""""""""""""I'm also expecting to use it for Chamfer, Shell/Offset, and what is called "DIRECT MODELING" functions like transforming an individual face and the surrounding faces extend to meet the edited face. That should be a good spot to wrap up v5 at that point."""""""""""""""""""""""""
SOLD!!!!!!
11034.80 In reply to 11034.78
Hi blackboard,
Probably not really too much because it's mostly swapping out internal geometry creation functions and not creating new UI.
Something like another month to get that stuff hooked up and maybe a couple more months beyond that for tuning and bug fixes.
11034.81 In reply to 11034.80
Nice!Its fast.I have last question, if i bought EDU v4 license 2 day ago i will have free upgrade to v5? or i will need to pay 100 dollars?
11034.82 In reply to 11034.23
I did a test, on a model, I'll do some tests during these days and then I'll share them, however on Linux the performance has improved a lot, I don't understand if this depends on something else but now everything is super smooth!
Great thanks
11034.83 In reply to 11034.81
Hi blackboard,
Sorry, I don't know when the free upgrade cutoff date will be yet.
There is also an EDU upgrade version as well.
11034.84 In reply to 11034.82
Hi pafurijaz,
That's great! There has been a couple of tweaks to avoid certain texture formats that did not seem to be supported well on Linux.
I would not have thought that it would make such a big difference but it must have been triggering some slow path.
11034.85 In reply to 11034.83
Thanks for information.
11034.86
Really nice update Michael!
David
11034.87
Great stuff, Michael, thanks for all the hard work.
I don't use MOI often (I'm mainly polygonal modeller/render guy) but when i do need to use it i always enjoy using/discovering new stuff.
Lewis
www.ram-studio.hr
Skype - lewis3d
11034.88
Hello,can people who bought a v4 octane license get access to v5 beta? the problem is that they don't have a license key but they do have a license, what should these people do in this situation?
11034.89 In reply to 11034.77
Hello,
I thought booleans were also involved a lot for filleting that they will be higher on the list ( I have nothing to complain about the actual booleans tho)
Switching those to ACIS will also mean we could have some 'direct' modelling enhancement like moving the cutter solid later in the design ? Or is that an other history based mechanics ?
11034.90 In reply to 11034.88
Hi blackboard,
There will be a separate v5 beta build for octane users that will be available in their account page.
I'll get that set up for the next beta release, there will be a new release soon with a bunch of bug fixes.
11034.91 In reply to 11034.90
it's for this bundle ?
https://home.otoy.com/octane2023/
11034.92 In reply to 11034.91
Yes, that one.
11034.93 In reply to 11034.89
Hi PaQ,
Right, booleans are an area that Solids++ does handle well, so there is not as much to be gained by switching them compared to filleting.
There are direct modeling functions in ACIS which should allow things like this. I don't know the exact details of how well it will work quite yet.
The direct modeling functions are not dependent on booleans being handled by ACIS.
11034.94 In reply to 11034.92
<< Yes this one
so the V4 of MOi ? Or a special one ? or a previous one ? or...
And can it works alone ? (Moi)
11034.95 In reply to 11034.94
That bundle currently includes MOI version 4. I will be making a v5 beta release for it as well, for the next v5 beta release.
11034.96 In reply to 11034.95
And these versions work as normal version ? They are "standalone" ?
Show messages:  1-16  17-36  37-56  57-76  77-96  97-106
