V5 beta Mar-28-2023 available now - ACIS fillets
 1-15  16-35  36-55  56-75  76-95  96-106
11034.56 In reply to 11034.55
Hi Death,
> I reinstalled, but no fillets or thumbnails after saving.
> Tried the regsrv32, but get this error message:
That's the previous beta version (May-22-2022):
The new one is MoI 5.0 beta Mar-28-2023 .
11034.57 In reply to 11034.56
Son of a ....!
Jeez, sorry about all that, what is the link to the latest beta?
Never mind, got it..
Thanks a bunch, sorry for my stooopid posts... :-)
EDITED: 4 Apr 2023 by DEATH
11034.58 In reply to 11034.57
Works like a charm!
Happy camper!
THANKS Again!
The fillets starting to work is the best news since years, I have been waiting for this!
Can't wait for the end results in vers. 5!
Great stuff, the grouping etc., very, very happy!
Thanks Michael and keep up the good work!
Jack
11034.59
Simple Fillet set test with ACIS. Cross Hatching modified with a Width Gradient in Illustrator.
11034.60
Hi Michael.
The 'join' command does not merge into one contour.
11034.61 In reply to 11034.60
Your curve was all wonky, ends didn't connect and weren't in the same plane.
Flatten everything by scaling
then select all ,
hit join, then show points and connect the 2 ends not overlapping,
select all,
join,
done
11034.62 In reply to 11034.57
Hi Death,
No worries, I'm glad it's working ok now!
11034.63 In reply to 11034.59
Hi Danperk,
Pretty cool look - kind of hand drawn style but not quite exactly.
Thanks for sharing it! - Michael
11034.64 In reply to 11034.61
Hi Death.
Thank you, I didn't even have any doubts that I was drawing in a different plane, apparently pushing out at the previous step somehow affected this, so I'll have to keep this in mind all the time.
11034.65 In reply to 11034.22
Withe this new version of ACIS fillet , can you put a rounded bevel of 0,15 mm
I join an example
Thanks a lot
11034.66 In reply to 11034.62
Hi Michael
With the new version of bevel
Can you put a rounded bevel (0,15 mm) to this model in attachment ?
Thanks a lot
11034.67 In reply to 11034.66
I can't do it with the V4
11034.68 In reply to 11034.66
your model is in cm!
And you want 0.15mm ?
And you have very curious tiny vertical faces...
EDITED: 5 Apr 2023 by PILOU
11034.69 In reply to 11034.66
That blocks on the right on the tiny faces! Not on the left...
I take only the front edge "curvated" not the tiny faces edges...
If i take something without tiny faces that works! ;)
Acis or Solid++
11034.71 In reply to 11034.70
Hello, I am excited about the new beta!
I am glad to see that you have added a new beta feature for managing Objects.
Now, I am building a new PC. I am planning to use the new beta on my new PC. I find this version very attractive and look forward to using it.
Thank you for your commitment to continual software improvement.
marzRX
11034.72 In reply to 11034.66
Hi Finema,
The maximum it will go is 0.04 units. To go larger the profile curves will need to be cleaned up some more to remove those tiny line segments that Pilou shows above.
I've attached a version that has those removed, it can now be filleted at your target 0.15 radius.
11034.73 In reply to 11034.72
Thanks Michael !
11034.74
Hello.On v5 dark color theme guide lines almost invisible.they have white color.Can you change it to grey\blue\red or btw something else becouse its unreal to work with that
11034.75 In reply to 11034.74
Hi blackboard,
The default dark theme draws the construction lines with an alternating black and white dashes. The white dashes have a high contrast against the darker viewport background, it should look like this:
Does it look different for you over there? Have you possibly changed the viewport background color to a light color?
You can make a customized color theme that has a different color. The setting for it is not currently exposed in the theme editor UI, you need to edit the theme definition file directly to change it. To do that got to the theme folder (Options > General > "Manage themes" > "Open themes folder") and open the file defines.inc in a text editor.
The line that controls construction line color is:
STRAIGHT_SNAP_LINE_ARGB_COLOR #B0FFFFFF
That has values for opacity, red, green, blue.
If you wanted to make it red you could put:
STRAIGHT_SNAP_LINE_ARGB_COLOR #B0FF0000
Show messages:  1-15  16-35  36-55  56-75  76-95  96-106
