V5 beta Mar-28-2023 available now - ACIS fillets
 1-10  11-30  31-50  51-70  71-90  91-106
11034.51 In reply to 11034.50
Hmm, that's weird, I just resaved one of the tests and it shows the .jpg for it.
But, I think that maybe the pic that the custom UI saves, unless that is what the new version is supposed to do?
I copied everything that said fillet, or fillets.xxx.
Size: 57.8 KB, Downloaded: 72 times, Dimensions: 1108x381px
11034.52 In reply to 11034.51
Hi Death,
The new version does not save any additional .jpg file, it saves an image that is stored inside the .3dm file and File Explorer windows will display that embedded image when viewing in a thumbnail displaying mode.
Only new .3dm files that were generated with this new beta will have the thumbnails in them.
Ok, but why are you copying those files? You'll need to leave these files alone and keep the Fillet.js and Fillet.htm files that are in the regular install.
If you overwrite Fillet.js and Fillet.htm with old versions from previous betas that's when you will have problems.
11034.53 In reply to 11034.51
Oh for the thumbnails, are you running the installer on the same machine where you are trying to view the thumbnails?
Because the thumbnail shell extension gets registered with the installer now, it won't be set up if you run the installer on some other machine and then just copy the files.
You can manually register the shell extension by opening up a command prompt with "Run as Administrator", then cd to the directory where you have MoI and run:
regsvr32 moi_lib.dll
A dialog should pop up "DllRegisterServer in moi_lib.dll succeeded." and then the thumbnail extractor shell extension will be registered with the shell to use for getting thumbnails out of .3dm files.
11034.54 In reply to 11034.52
OKYDOKY, I will re-install and try again.
I let you know what happened when done...
EDITED: 4 Apr 2023 by DEATH
11034.55 In reply to 11034.53
I reinstalled, but no fillets or thumbnails after saving.
Tried the regsrv32, but get this error message:
11034.56 In reply to 11034.55
Hi Death,
That's the previous beta version (May-22-2022):
The new one is MoI 5.0 beta Mar-28-2023 .
11034.57 In reply to 11034.56
Son of a ....!
Jeez, sorry about all that, what is the link to the latest beta?
Never mind, got it..
Thanks a bunch, sorry for my stooopid posts... :-)
11034.58 In reply to 11034.57
Works like a charm!
Happy camper!
THANKS Again!
The fillets starting to work is the best news since years, I have been waiting for this!
Can't wait for the end results in vers. 5!
Great stuff, the grouping etc., very, very happy!
Thanks Michael and keep up the good work!
Jack
11034.59
Simple Fillet set test with ACIS. Cross Hatching modified with a Width Gradient in Illustrator.
11034.60
Hi Michael.
The 'join' command does not merge into one contour.
11034.61 In reply to 11034.60
Your curve was all wonky, ends didn't connect and weren't in the same plane.
Flatten everything by scaling
then select all ,
hit join, then show points and connect the 2 ends not overlapping,
select all,
join,
done
11034.62 In reply to 11034.57
Hi Death,
No worries, I'm glad it's working ok now!
11034.63 In reply to 11034.59
Hi Danperk,
Pretty cool look - kind of hand drawn style but not quite exactly.
Thanks for sharing it! - Michael
11034.64 In reply to 11034.61
Hi Death.
Thank you, I didn't even have any doubts that I was drawing in a different plane, apparently pushing out at the previous step somehow affected this, so I'll have to keep this in mind all the time.
11034.65 In reply to 11034.22
Withe this new version of ACIS fillet , can you put a rounded bevel of 0,15 mm
I join an example
Thanks a lot
11034.66 In reply to 11034.62
Hi Michael
With the new version of bevel
Can you put a rounded bevel (0,15 mm) to this model in attachment ?
Thanks a lot
11034.67 In reply to 11034.66
I can't do it with the V4
11034.68 In reply to 11034.66
your model is in cm!
And you want 0.15mm ?
And you have very curious tiny vertical faces...
EDITED: 5 Apr 2023 by PILOU
11034.69 In reply to 11034.66
That blocks on the right on the tiny faces! Not on the left...
I take only the front edge "curvated" not the tiny faces edges...
If i take something without tiny faces that works! ;)
Acis or Solid++
Show messages:  1-10  11-30  31-50  51-70  71-90  91-106
