V5 beta Mar-28-2023 available now - ACIS fillets
 1-3  4-23  24-43  44-63  …  104-106
11034.4 In reply to 11034.3
Heck awesome addition this was one thing I didn't imagine, an external kernel support, now who knows what the future will be for this beautiful application.
And thanks for the rebuild command :)
EDITED: 2 Apr 2023 by PAFURIJAZ
11034.5 In reply to 11034.1
Very impressive update!
I'll need more time to read, study and understand... explore and try out.
Tried out ACIS fillet of a box.
Minor typo in Notes: "didsabled":
Update windows installer
Add checkbox to installer for "Create file associations", so that changing file associations can be didsabled by the user.
(Windows 11 "Defender" very briefly blocked install.)
I suppose ACIS company charges Triple Squid Software Design a fee per user?
EDIT to correct using old taskbar MoI icon:
Regarding Theme change for the Object, Type and Style menus:
The old bug of open menus not having Theme update has been corrected!!!
But it is necessary to create a NEW taskbar ICON for the new beta, rather than using the old taskbar ICON.
Using the OLD taskbar ICON shows the ACIS Fillet change, but the Theme update correction does not occur.
Well, Wierd, but after creating the new taskbar ICON, the Old MoI taskbar ICON no longer does ACIS
Did not observe any "crosstalk" with MoI4 menu colors, from MoI5b themes.
EDITED: 2 Apr 2023 by BEMFARMER
Even this can be realized by a Boolean Diff with the error surfaces Fillet! ;)
11034.8 In reply to 11034.6
I began to wonder if I installed the new beta properly???
If you use Window (10 or 11) and taskbar icon for MoI:
DO create a NEW taskbar ICON for new MoI5 Beta!
I have re-edited this post, and my post 6, to correct my many incorrect/inaccurate statement blunders :-).
11034.9
Nice, thanks for this new beta !
11034.10 In reply to 11034.1
You've been working hard! I'm excited about face.analyticFrame and all these other improvements.
- Peer
11034.11 In reply to 11034.5
Corrected, thanks!
I'm sorry it's probably best if I don't discuss the licensing terms. But I will be absorbing the licensing cost, Moi prices will remain the same.
11034.12 In reply to 11034.6
Great! Yes there were some bug fixes for this also.
Sorry I'm not really understanding this part. If you want the new beta to be pinned to the taskbar after you launch it you will need to right click on it in the taskbar and choose "Pin to taskbar" on the menu that pops up.
The new beta will not automatically overwrite any previous pinned shortcuts.
Yes there were some bug fixes for this as well.
Thanks, - Michael
11034.13 In reply to 11034.7
Yes, the old filleter would try to leave fillet surfaces behind when it was not able to trim a hole for them. That's so you could have a chance at salvaging it.
But it's a lot more convenient if it just works.
Cool! (Acis) Solid++ fails
But there is a secret! ;) Rotate the cylinder before the Boolean Union!
11034.15 In reply to 11034.14
Hi Pilou, with ACIS fillets you can do it without rotating the cylinder if you do it in 2 separate chunks:
I'm not sure exactly why yet.
Maybe I need to mark the vertex at the collapsing point to not attempt to be smoothed there.
Also in some cases it can help to not try to include already smooth edges as fillet targets.
11034.16 In reply to 11034.15
Thx for the trick but not sure in this case that is so appetizing! :)
11034.17
Thanks for the new Beta Michael!
I like how you've set up the Hatch for AI export, creating hatch groups per/face and sub-groups for min & max. :)
EDITED: 2 Apr 2023 by SBEECH
Size: 548.6 KB, Downloaded: 231 times, Dimensions: 2929x1316px
11034.18 In reply to 11034.17
Thanks Dan, I hope that can be useful for getting a different illustration feel.
11034.19 In reply to 11034.18
The exported grid is fantastic, I've been wondering for some time if it was possible to export the surfaces in mesh but using the nurbs patch topology, i.e. export the grid of nurbs patches in mesh.
Another thing seem more responsive in my case with Linux!
Greetings
The ACIS fillet does not seem to apply to 2D object comprised of closed curves???
ACIS fillet applies to a Solid.
ACIS fillet seems to apply to an extruded object, even if it is not a solid.???
11034.21 In reply to 11034.20
Hi Brian, ACIS works with surfaces and solids but with curve is useless.
11034.22 In reply to 11034.20
Yes that's correct, there isn't anything different for curve filleting, the new stuff is for edge based filleting.
It can be a solid or a joined surface.
11034.23 In reply to 11034.19
Hi pafurijaz,
> The exported grid is fantastic, <...>
Do you mean the new cross hatching for 2D drawings?
I'd love to see some examples if you're using it.
There were a couple of improvements for running on Wine.
Thanks, - Michael
Show messages:  1-3  4-23  24-43  44-63  64-83  …  104-106
