V5 beta Mar-28-2023 available now - ACIS fillets
 1-9  10-29  30-49  50-69  70-89  90-106
Works with 0,5 radius ...with little error on your model...
but not on other models...but curiously we must also take 0.5 maxi!
here the seams is deported...
EDITED: 3 Apr 2023 by PILOU
11034.31
Michael,
Congratulations on the latest BETA! I can't wait to dive into the new features! Even having SharkCAD Pro and Rhino3D, Moi has now become my go-to application for my 3D designs. The power and simplicity are perfectly integrated! And it makes concepting and turn-around super fast!
One question: on the Scene browser assignment list, is it/would it be possible to make this a right-click instead of a left-click, keeping the existing behavior (click-assign)? After getting so used to the way Moi handled these object assignments in the past, seeing the menu pop up on a simple click feels a bit jarring. Great concept, but would it be possible to use right-click, even if just as an option? (Or is it perhaps changeable via a script?)
Thanks!!
jdb
On another note: Is there a way to change the dialog font size (seem too large for my display)? I have found where to change the UI fonts (made them smaller), but I am probably missing something... Thanks again!
11034.32 In reply to 11034.24
> Acis works but only one by one...does this normal ?
It will work if you select all the edges coming off that central point instead of only some of them.
With a mix of some edges not being filleted combined with mixed convexity that might be a difficult corner configuration.
So that might be normal I'm not entirely sure. I have observed other situations where doing some fillets individually can succeed in ACIS but I don't know yet if this is a limitation of ACIS or if it's caused by something I'm doing when transferring geometry over to it.
11034.33 In reply to 11034.25
Hi Charlie, thanks for testing the fillets.
> It seems there are things that the Solids++ fillet can do that the ACIS can't. Will it be sticking around?
Yes, the switch between fillet libraries will be staying for quite a while.
There are some cases where Solids++ can generate a fillet where ACIS can't, mainly on things where the fillet is trying to go around a bend that is smaller than the fillet radius. Solids++ can slice out that self intersecting fillet area if it's not too complicated, but ACIS won't do those cases.
But your case here looks more like a bug in MoI's conversion to and from ACIS geometry, that is an area that I'm still actively working on. I'll add your file to my list to test with.
With the attached version I replaced 2 of the planes and it's working ok on this one.
11034.34 In reply to 11034.33
@ Michael
you can modify the Acis libraries or they are "closed" ?
When you say replaced 2 Planes, what is exactly this ? (faces ? ...
Works now fine in one pass with Acis indeed! :)
11034.35 In reply to 11034.34
I don't have the source code for the libraries so I need to ask the ACIS developers (a company called Spatial) to make modifications, I am not able to do it myself.
I replaced 2 planar faces.
11034.36 In reply to 11034.31
Hi jdb,
> of a left-click, keeping the existing behavior (click-assign)? <...>
Sorry no there isn't anything set up to modify that back to the old behavior. But you can use right click on the new one which will do an assign without showing the menu. Also Ctrl+Left click is a shortcut for rename.
There is a setting for it on the Options dialog under Options > General > "UI size" :
Thanks, - Michael
11034.37 In reply to 11034.36
Thanks for the quick reply and workaround!
And a big DUH on the UI font. I knew I had seen it before :)
jdb
11034.38 In reply to 11034.35
Ok i have found the 2 faces to remplace but any idea of what that made ? :) (up face cylinder and adjacent face box)
Better welding edges ?...
11034.39 In reply to 11034.38
Not sure yet, but probably different orientations on the outwards surface normals.
11034.40 In reply to 11034.39
There are gaps in the complete original object
Flip faces don't make no more, only select edges of an erased face then Plane make something...then global boolean Union
11034.42 In reply to 11034.11
“”””””” I'm sorry it's probably best if I don't discuss the licensing terms. But I will be absorbing the licensing cost, Moi prices will remain the same.””””””
Wow…. Just Wow!!!
Thank you!
I don't know if Spatial knows yet the jackpot they just hit!
11034.43 In reply to 11034.1
And in this corner... The undisputed champion at 51.4 MB
Once again demonstrating Sheer force of will!
11034.44 In reply to 11034.43
Hi Burr, yeah but ACIS added in around 15MB.
Still pretty lean by today's standards though.
11034.45
Wow this is such an amazing update!
I love Moi 3d, one of best tools I have the pleasure of working with everyday!
In this system you can't increase the radius up the first intersection of fillets between them! Here it will be 1!
11034.47
On my version (latest beta) it doesn't show the LIBRARY option.
What do I need to do to see it?
Also: I don't see any thumbnails in explorer (win 10)
TIA
EDITED: 4 Apr 2023 by DEATH
11034.48 In reply to 11034.47
Hi Death,
What do you have selected when you run the fillet command? If you have curves selected then you won't see it, if you have edges selected then you should see it.
Are you testing with a default install or are you applying customized UI? Are you possibly overwriting the regular fillet command with an older version?
Can you show a screenshot of an explorer window?
11034.49 In reply to 11034.48
I am using my old standby custom UI, and I copied the fillet files from the beta program directory to make sure.
Included screenshots
Oops, I forgot:
The clamp.jpg is the one generated from the custom UI, the other test files don't have it...
Show messages:  1-9  10-29  30-49  50-69  70-89  90-106
