Fillet not working well
All  1-8  9-12
11029.9 In reply to 11029.1
If you rotate the edges on the two balls to be away from the fillet then the fillet will be successful (at least in MOI5 beta)
11029.10
Thanks for your answer Pilou.
There was a small mistake on my part.
The circle was not exactly round. Therefore, the center was not exactly in the middle of the circle.
I knew that with the helplines. ;)
Thanks anyway.
11029.11 In reply to 11029.9
Yes the curves generator generate some troubles! It's a good habit to separate them!
You can also use the script of Max Smirnov for find the Center of Gravity! ;)
(just make some thickness to your surface! ;)
https://moi3d.com/download/scripts/max/CVolume.v.3.0.2022.05.24.zip
Show messages: All  1-8  9-12
