Embedding an MOI3D Object into Microscoft Office
11028.1
As part of my new course for new MOI3D users I wanted to demonstrate some uses of creating 3D objects beyond 3D printing.
Now, all MS Office products can bring in 3D objects of the correct format.
If we want full color, we can't directly go from MOI3D to Office.m But, by going through a relatively simple workflow through a virtually free product called MeshMolder ($6) and a final conversion in the free Meshlab to .PLY, we can get there.
Here is my first test. Click on the .gif to animate
EDITED: 28 Mar 2023 by TMEEKS
Size: 904.3 KB, Downloaded: 69 times, Dimensions: 1902x1066px
Size: 1.9 MB, Downloaded: 103 times, Dimensions: 640x360px
11028.2 In reply to 11028.1
So end final format for import inside MOffice is the PLY ?
There are no other formats possible ?
Simple format OBJ from Moi3D gives colors inside the free Microsoft 3D Builder
So here just one free gobetween! ;)
EDITED: 29 Mar 2023 by PILOU
11028.3 In reply to 11028.2
Thanks, Frenchy! I will check out 3D Builder.
I appreciate it.
Tom
11028.4 In reply to 11028.2
Hi Frenchy,
It turn out that the .3MF file format is more reliable than the .PLY or the .OBJ.
I managed to figure out the workflow to go from MOI3D to MSOffice using Meshmolder, Meshlab and 3D Builder.
I couldn't find a way to import the color .OBJ I had imported to from MOI3D because there is no material file. I needed to unwrap the UV in meshmolder and save the ,png, which I cleaned up in an image editor. Then I imported that mesh and png into Meshlab and exported to create an .OBJ having a material definition file.
The Meshlab export .OBJ, .MTL and ,PNG where brought into 3D Builder and it was used to export the final .3MF file.
I am not sure how many people are crazy enough to take that many steps besides myself; but, here is a video that demonstrates the process from start to finish.
NOTE - UPDATE: Thanks to Frenchy and Michael the link below is obsolete! I created a new video that is much shorter showing a more direct route.
https://www.dropbox.com/s/9l7wk0j0llx7isx/MOI2Office.mp4?dl=0
New shorter video link...
https://www.dropbox.com/s/lwkz2g4lkd44sct/MOI23MF.mp4?dl=0
EDITED: 30 Mar 2023 by TMEEKS
11028.5 In reply to 11028.4
Hi Tom, MoI will write a .MTL material definition file when you generate an .obj file, unless it has been disabled under Options > Import/Export > OBJ options > "Write .mtl file".
11028.6 In reply to 11028.5
Thank you!!!!
That saved a billion steps and will make for a MUCH shorter video!!!!! LOL!
79 years old and still learning every day!
Tom
11028.7 In reply to 11028.6
No problem Tom!
The materials will come from the style list in MoI.
11028.8 In reply to 11028.7
It works like a charm!
I had tried it after Frenchy indicated it should work and I could not bring in the colors for whatever reason. So, I went searching for the long route.
I tried again after you answered and made sure the .MTL file was being created. It was. But, I THINK I thought 3D Builder was asking for the .PNG file when it was actually asking for the .MTL file. In any case, I now have the right workflow, thanks to you and Frenchy.
It's a LOT cleaner, too. With no image editing required!
I love hanging around with people smarter than me!
I have to admit that color 3D is a complete mystery to me beyond the simplest of levels. It's just plain voodoo! LOL!
Tom
New 7 minute video:
11028.9 In reply to 11028.8
Excellent last video and workaround! :)
Maybe you must ask to Michael to change the tittle in
Embedding an MOI3D Object animated into Microscoft Office !
If you are agree i have added your tutorial animation on my Moi3D site :)
https://moiscript.weebly.com/truc-astuces-2.html
If you want a link about something of your creation (s) i will add it in a minute!
11028.11 In reply to 11028.10
Thanks, Frenchy and Michael.
I am working on a new audio track for the video. (The current track was a bit stream-of-consciousness and hesitant.)
But, when that is finished, I would love to have a link published.
I will let you know when the video is completely finished.
Tom
11028.12 In reply to 11028.10
Frenchy,
Here is the permanent link to the video on YouTube
https://www.youtube.com/watch?v=HMlgzggYdJE
11028.13 In reply to 11028.12
The Video is Private, and not available.
11028.14 In reply to 11028.13
Please try the link again. It shows me now that it's public. But, I want to make sure.
11028.15 In reply to 11028.14
Yep it's working! ;)
But seems not more! :)
EDITED: 14 Apr 2023 by PILOU
