Hi Phiro, sorry no there isn't currently a surface simplify method in MoI.
re: 335 000 faces - that's really way too dense. The SubD converter is intended to be used to convert sub-d control cages which should usually be fairly sparse.
If you're converting dense scan data you'll probably need a reverse engineering tool rather than the sub-d converter.
