"make2d" oddities
All  1-14  15-19
11025.15 In reply to 11025.14
Hi Ad,
> Another thought that came to me, would it be possible to automagically have all the line segments,
> that surround each face joined.
Pretty difficult to make that happen currently at least. To start with as you have noted there are often little pieces which are hard for a joiner to process automatically.
Additionally on edges shared between 2 faces those would need to be duplicated?
> I probably should make a screenshot to show what I mean. Or is there a way to
> loop select edge loops on 2D entities.
Sorry, no there isn't that kind of loop selection available currently.
And why not use the PDF export from MOi3D ?
Seems you have the same different projects view 3D of any position of the object in the 3D SPace to the flat sheet !
and seem there is no problem of intersection and little part of curves... at the 500% zoom
11025.17 In reply to 11025.15
>Pretty difficult to make that happen currently at least. To start with as you have noted there are often little pieces which are hard for a joiner to process automatically.<
Sorry I threw that at you. I haven't really thought through this, I just thought out loud. But after some more thinking, I realized this is probably a
no-go. And like you said, on top of that, some edges would have to be duplicated.
@Frenchy Pilou, the pdf export was actually the first thing I did, but if I have to clean up things, it is actually easier to do right there in Moi. At least for me.
Thanks to everybody for your input and suggestions, definately got me a step further.
11025.18 In reply to 11025.17
Hi Ad,
Have you tried out the latest v5 beta? It seems like hidden line removal is less sensitive to object size now.
- Peer
11025.19 In reply to 11025.18
Hi Peer,
I just used make2d with a different part, on the April 8 Beta.
The results were much better, but like I said this was a different
part.
After trying several different options, including other software,
I decided to stick with Moi. Just have to do some clean up, but
either way I have to prep things for my purpose anyway and doing
it in Moi is the most efficient way for me personally.
Ad
Show messages: All  1-14  15-19
