Unable to Boolean Subtract
All  1  2-6
11022.2 In reply to 11022.1
Hi Andy, it's a lot more difficult for booleans to handle things that have coincident or nearly coincident surface areas.
So for your cut piece it would be good for it to be 2mm thick with 1mm going down like you have now but the other side 1mm above rather than flush.
Does it work ok if you get it set up like that?
Message 11022.3 deleted 22 Mar 2023 by MICHAEL GIBSON
11022.4 In reply to 11022.1
HI Andy, if you turn on control points for the curves you can see 2 red squares:
Those are spots that have several curve control points stacked up on top of each other. They may need to be cleaned up first.
11022.5 In reply to 11022.1
Hi Andy try with this one.
11022.6
Many thanks Michael - works great! Andy
Show messages: All  1  2-6
