Compatibility Questions?
All  1  2-13
11021.2 In reply to 11021.1
I just tried something. I went into Rhino and exported this simple SubD model in OBJ. sent it over to Moi3D and tried to open it with the OBJ. import. No go. Won't load.
So it looks like The Sub D models I create in Rhino. I won't be able to open them in Moi, Sure hope I 'am missing something.
I will say I learned how to create the coolest SubD models in Moi3D following Pilou's tutorials. Thanks Pilou for all that you do.
Just thought about it. If I can't switch from smooth to flat in Rhino the Obj import will not work in Moi3D.
So in a way Rhino has made their program to not handshake with Moi. That kind of bums me out. I thought because they both use the 3dm file format they would cross reference flawlessly. Always learning.
EDITED: 22 Mar 2023 by SPECKTECH
11021.3 In reply to 11021.1
Hi Specktech,
For bringing a Rhino SubD object into MoI, use the ToNURBS command on it before exporting to a v5 3DM file:
https://docs.mcneel.com/rhino/7/help/en-us/commands/tonurbs.htm
Or also another route is use ExtractControlPolygon on the Rhino SubD object and then export the polygon mesh object to an .obj file and use the MoI subd converter under SubD > Convert > "From file".
11021.4 In reply to 11021.2
Hi Specktech,
Can you please post the .obj file here or e-mail it to me at moi@moi3d.com so I can take a look?
Thanks, - Michael
11021.5 In reply to 11021.3
I completely forgot about that step. Thank you so much Michael. Have a wonderful day.
11021.6 In reply to 11021.5
Hi Specktech,
Also see here for some conversion utility programs that you can set up to be able to Ctrl+C/Ctrl+V copy/paste NURBS objects from Rhino to MoI:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9890.18
11021.7 In reply to 11021.2
@ Specktech Thanks! :)
Here the thread about subdivision inside MOI : https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
The funny things is that you need only 5 tools sSplit, sBridge, sScale, Extrude, sSubdividBeta9 for make SUbdivision inside Moi!
But sufficient for cool little objects directly Nurbs!
Sure that is some rustic against dedicated prog like the free Rocket3F but... (who has a direct Bridge in the 2 ways with MOI) https://rocket3f.com
Always for the fun...I have found something free Online between Blender & Tinkercad ! :)
Figuro Designer! :) (polymodeler of light subdivision)
https://www.figuro.io/Designer
EDITED: 22 Mar 2023 by PILOU
11021.8 In reply to 11021.5
I just tried that in quite a few different ways. Still not able to get the file to load. I will recreate a few simple subD models and test them. I will send a few as soon as I get a few more tests. Thanks again for all your tips.
11021.9 In reply to 11021.8
Update. I have been trying many different things. I will try to explain what I am finding.
I go into Rhino, Select SubD, create a super simple subD box from the primitives. I tweak it a little extrude it a bit and scale it out. Then I convert it to nurbs,
Then I go to export. As soon as I select export in Rhino 5 I feel like this step removes the functionality of the file. Its like the programming for version 7 is not compatible with any lower version exports.
I am looking and reading at that file conversion script you posted. With the copy to clipboard path. Going to work on getting this setup.
So it seems like the subD coming from Rhino won't load as soon as its converted to version 5. It does make sense. Lots of features including SubD are quite new for Rhino.
11021.10 In reply to 11021.9
Hi Specktech
Before you do the export are you selecting the version that was converted with the ToNURBS command?
What you described could happen if you had the SubD object selected when you did the v5 export.
Can you please post the .3dm files (v7 and saved as v5 versions) that you were describing here or e-mail them to me at moi@moi3d.com so I can take a look?
Thanks, - Michael
11021.11 In reply to 11021.10
I think I just figured out something. I might not have been doing the mesh to nurbs conversion correctly in Rhino. I just did a few more and I got it to load into Moi.
It was really giving me a fit. But I just kept trying it. I think I might have figured out my problem. My end goal....Might sound silly. But I am going to use Moi3D any time that Rhino kicks me. I have slowly learned how to fix so many models using Moi3D.
And quite often I will send my Moi files over to ViaCAD to run certain fillets. Using Rocket and Wings and Blender sending them to the Obj importer in Moi. Its amazing learning how to combine all these programs. I think I might be okay for the moment....Thanks Michael. Have to say Michael every file I load into Moi3D just looks so beautiful. I use that porcelain lighting and it always looks so incredible. I personally think all Rhino users should have an add on called Moi3D. Thanks again.
11021.12 In reply to 11021.11
That was exactly what I was doing. I must have had the model selected when I was doing the export. Gee whiz. Thanks M.G.
_importObj works like a charm with a Figuro Designer Object ! :)
But seem a little problem with SUBD Native!
Show messages: All  1  2-13
