Distorted edge appears on the cylinder
All  1  2-4
11014.2 In reply to 11014.1
Hi marzRX,
I see the same problem, but only if I sweep both circles. If I sweep a single circle then boolean union between the cylinder (resulting from sweep) and a sphere works fine. In your screenshot it looks like the bent cylinder has a constant diameter. So, maybe sweeping 1 circle will give the shape that you want.
- Peer
11014.3 In reply to 11014.2
Hi, Peer
Thank you. Your answer is helpful.
Single circle sweep work fine. I will also try about the curved sweep.
Yes. same diameter. :)
marzRX
11014.4 In reply to 11014.3
Thank you ! I can now make it without artifacts.
I have had Boolean-Union failures for cylinders and spheres, and Boolean-Diff failed even if sphere and cylinder were combined.
All of these problems have been eliminated and modeling can now be done in a short time. ;)
marzRX
Show messages: All  1  2-4
