Bridge from Silo to moi 3d
All  1-2  3-7
11006.3 In reply to 11006.1
Hi another simple mesh modeler like Silo maybe checkout this if fit your needed.
http://www.wings3d.com/?page_id=84
or
https://github.com/k3d-io/k3d/releases
I forgot the most important and powerful with modern UI
https://www.rocket3f.com/
I don't say Blender because I think you're aware about.
Greetings
11006.4 In reply to 11006.1
Hi vespanut,
> How or what format would I import figures/sculptures into Moi 3d to size, include simple
> attachment point for parts made in moi.
It depends on how the models were constructed in the poly modeling program.
If they are sub-d smoothed models, then those can be converted into MoI by exporting the sub-d control cage to .obj format and then using the Sub-D converter in MoI under SubD > Create > "From file" which will generate a smooth surface in MoI out of the Sub-d control cage.
If the models were not done using sub-d smoothing in the poly modeling program then that type of data is generally not suitable for conversion into CAD surfaces and solids automatically.
PS and Rocket3D is free (or Pro) & has a direct Bridge to Moi in the 2 Ways! ;)
Rocket <---> Moi3D By ShortCut or pressing an icon !)
In Rocket3F
(Pont = Bridge in French ;)
In Moi3D
EDITED: 6 Mar 2023 by PILOU
11006.6
thanks for the information! I came across Rocket f3. Looks perfect I only wish they had a Mac version Thks again
11006.7 In reply to 11006.6
I am affraid that is no Mac Version!
You must use an emulator or a Windows version for MAc!
Show messages: All  1-2  3-7
