Select all faces inside an edge loop?
All
1-5
6-11
Chris (CEEN)
4 Mar 2023 (6 of 11)
11003.6
In reply to
11003.5
that is absoutely awesome! Thank you very much. You just accelerated my workflow tremendously!
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Frenchy Pilou (PILOU)
5 Mar 2023 (7 of 11)
11003.7
not works ?
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/not_work.3dm
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
5 Mar 2023 (8 of 11)
11003.8
In reply to
11003.7
Hi Pilou, it doesn't work on your case there because those are independent surfaces not joined to each other.
If you select those surfaces and use Edit > Join to glue them together into a connected object, then it should work.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
5 Mar 2023 (9 of 11)
11003.9
In reply to
11003.8
Excellent!
EDITED: 5 Mar 2023 by PILOU
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
5 Mar 2023 (10 of 11)
11003.10
You can click any face inside the loop!
here the last (or the first depending of your point of view! :)
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Chris (CEEN)
6 Mar 2023 (11 of 11)
11003.11
In reply to
11003.10
Yes it is a great implementation by Michael. I already use it with shortcut and it is such a great addition to Moi. That workflow helps in many cases.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-5
6-11
