Romansco fractal script !?
All  1-2  3-4
10988.3 In reply to 10988.1
You also might try experimenting some with MoI's circular array command, applying some vertical and radial stepping.
For example starting with this:
Then a circular array with some vertical and radial stepping used:
Scale array used ( http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109 ):
Circular array applied again:
10988.4
Thank you Michael, I have used Array so far only for simple radial
multiplication and not considered using it in the way you demon-
strated - very good !
Show messages: All  1-2  3-4
