Ring with anti skid break
 1  2-21  22-29
10987.2
10987.3 In reply to 10987.1
Hi Mala, I might need to see a sketch approximation of what you want to be sure I understand.
But maybe one approach could be to model the ridge as a separate object then boolean union it with the ring and fillet the edges, something like this:
EDITED: 17 Feb 2023 by MICHAEL GIBSON
10987.4 In reply to 10987.3
Michael, thx.
It seems to be a misunderstanding coming out of my poor english.
The line should be pretty near in shape like I showed in the initial beginning of the thread. But the direction is to the other side.
Means not the bend like the red line. The green line is the goal.
EDITED: 28 Feb by MALA
10987.5 In reply to 10987.4
Hi Mala, I'm not really understanding how you would expect the green line to connect up with the ring:
10987.6 In reply to 10987.4
Dir
Exact same blend as the red line. But convex and concave of blend reversed...
10987.7 In reply to 10987.4
Is this curve in your file a path that you want the protrusion to follow? :
I set up some profile curves to do a sweep using that path as the sweep rail:
The idea is to make the protrusion modeled as a separate object to sink down into the ring so they can be booleaned with each other and then put a fillet on it:
But like I was saying before if the protrusion is vertical it is not over the ring and will go off of it:
10987.8 In reply to 10987.4
Burr's looks good!
Here's a try with making a sweep again but with the profiles rotated at an angle rather than being straight up.
Then it's booleaned and filleted:
10987.9 In reply to 10987.8
Yours looks much more variable or customizable for adjusting the shape result.
I would go with this.
10987.10
Thanks a lot for your tries. They give me an idea of the workflow.
Here is a little bit more the goal I need to reach. However, as gentle waves all around.
10987.11 In reply to 10987.10
Hi Mala, another technique that could be good is if you are able to form that centerline fin with the shape you want then you can use the Transform > Deform > Flow command to map an already swept world-axis-aligned shape onto it.
The advantage to this is that it is much easier to adjust the shape of the sweep when it's constructed straight in a world axis direction.
To do this you create a regular plane and construct the sweep based on that. Then you select the sweep and run the Transform > Deform > Flow command, and select the plane as the base surface and the fin as the target surface. Note that where you click on the base and target surfaces is significant for controlling how they will be matched, some info here:
https://moi3d.com/4.0/docs/moi_command_reference8.htm#flow
That looks like this:
Then it's Edit > Trim to cut the pieces up, Edit > Join to glue them together and Construct > Fillet to round the edges:
10987.12 In reply to 10987.11
Ooooooâ€Ĥâ€Ĥ
Ahhhhhâ€Ĥâ€Ĥ.
10987.13
I agree with Burr Man - ahhh oooh - I try it out this afternoon. THANK YOU!
10987.14
A start. Yes. Pretty cool. The only thing that's not good yet are the sharp, top edges running out to the cylinder. They should be softer. However, the filleting stops at 1.5 mm.
Message 10987.15 deleted 20 Feb 2023 by MALA
10987.16
This is "exactly" the shape of my brake. However, the shape is not yet perfect. I have done a two rail sweep. Is it the edges of the contour line? Because it is ideal from the side, but not from above. Do I have to change that?
10987.17 In reply to 10987.16
Hi Mala, I'm sorry I'm not understanding what you want to have it do different than what you currently have.
One thing though is if you edit the middle curve so that it's centered you can use it as a scaling rail to control the height.
Like this:
10987.18 In reply to 10987.16
try the attached network solution it gets rid of the pinching on the ends.
Barry
10987.19
Hi Berry,
your model is very near to the goal I try to reach. Thanks a lot!!!
I need to reshape the profiles rounder what I did now. And I must reshape the height line for sweeping.
I fail after so many tries with reshaping the height line. Why is it not possible to round the ends of the heigtht line with filleting? Or do I have to reconstruct the height line in an other way?
best, Mala
10987.20
Shit - I guess I got it. I tried so many times the arc tool with two deffinition points...and failed always. Now it worked. And I was able to make a relatively proper heightline. BUT - not fully perfect: At the end of the banana there is a little irritation...but it should work. Best, thx, Mala
10987.21
...hmmm´, like thought. I can flow deform the banana. But the filleting at the ring segment: calculation fails. No idea how to construct the banana better than how it is now?
Show messages:  1  2-21  22-29
