Shortcut for line control points?
10984.1
Good day.
How do I setup a shortcut to select the line control points?
Thank you!
10984.2 In reply to 10984.1
Any free Shortcut in the first column & juste type Line in the second Column
or Press Tab and write Line (line LinE LIne etc... but without spaces )
10984.3 In reply to 10984.1
Hi Matadem, do you mean you want to set up a keyboard shortcut that does the same thing as clicking the Edit > "Show pts" button in the side pane?
If so then go to Options > Shortcut keys to add in a new shortcut key and for the command part put in: ShowPoints
10984.4
@Frenchy ...I did not quite understand :/
@Michael attached the needed one.
Thanks!
Size: 14.9 KB, Downloaded: 37 times, Dimensions: 160x146px
10984.5 In reply to 10984.4
Hi Matadem, for that one put in Curve for the command part of the shortcut key.
10984.6
Got it tnx!
Without image that was a little difficult to understand the question! :)
