Elephant on MoI5 beta
10980.1
I had installed [elephant](https://github.com/nkallen/elephant/releases/tag/v0.1-alpha) on MoI 5.0 beta May-20-2022, then load the nod file at hand but an error occurred.
Could the current elephant (v0.1-alpha) not support on MoI 5.0 beta? Is there a way to fix it?
Please advise.
Size: 21.9 KB, Downloaded: 58 times, Dimensions: 591x269px
10980.2 In reply to 10980.1
Hi wori, newer versions of the node editor work ok on the v5 beta, I think the one you have there is old.
Try Nodeeditor 1.1 jms from:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9358.1
There are links to some other versions too I think at https://moi3d.com/wiki/nodeeditor .
Nodeeditor is running well on MoI5beta, the same as on MoI4. (As far as I can tell with a few programs tested.)
(With the version Michael linked to, per my recollection.)
10980.4 In reply to 10980.2
Of course, I had tried nodeeditor1.1, but its update time is 2020/09/14.
Elephant has been released on Mar.2, 2021 (refer to https://github.com/nkallen/elephant/releases/tag/v0.1-alpha).
And there are special instruction pages on https://moiscript.weebly.com/biblio-elephant.html.
But is Elephant old?
10980.5 In reply to 10980.4
Hi wori,
That's an experimental version branched off from an older version, don't use that one.
Use Nodeeditor 1.1 jms from:
https://moi3d.com/forum/index.php?webtag=MOI&msg=9358.10
10980.6 In reply to 10980.4
<<And there are special instruction pages
Yes ;) All is explained...all variations :)
https://moiscript.weebly.com/install-elephant.html
Nick Kallen was here experimenting a bit. But he stopped and is pursuing his own software, plasticity.
I dont know if that elephant version has any “benefit or addition” to elephant? Nothing ever developed in it?
James version is the newest and most Robust. Max’s version was the base project and release.
Unless Max returns and pursues Elephant again, should probably highlight James’ version as what to move forward with…..
2 cents.
10980.8 In reply to 10980.7
Thank you for all, I understood to use 1.1 jms.
I think it has the potential to be one of the killer features of MoI, so hope to continue to develop it.
