Lag on large files (V4)
All  1  2-3
10978.2 In reply to 10978.1
Hi Skywolf95, there are some settings you can adjust to help with large files.
Before loading your heavy file, go to Options > View > Meshing parameters and set "Mesh angle" to a rougher angle like 25 or 35 degrees and uncheck "Add detail to inflections".
That will make for a rougher display mesh for drawing shaded surfaces, the default is fairly dense.
Also maybe uncheck "Display hidden lines".
10978.3 In reply to 10978.1
Also re:
> or is the V5 beta better at handling large files so i should upgrade?
V5 does have display performance improvements in some areas, especially for annotation text.
Show messages: All  1  2-3
