Is there a flatten script?
All  1-4  5-8
10971.5
I use the handles but it is time consuming when you have about 30 pieces and get lost :/
Michael that shortcut works perfect,
Thank you!
10971.6
Hello,
Is there any way to also make this work using the (non-existant) floor as a target ? As if I am not mistaken, even using the top Cplane as target seems to require some object on the floor to project to, which somehow defeats the purpose of using a Cplane as a target (if I am understanding Project correctly).
I suppose what I am trying to get at is that it could be useful to have a Cplane as both as the target to project to, as well as the normal direction to project along ...
10971.7 In reply to 10971.6
Hi Pior,
When you use the project to cplane option in the Project command, the cplane is used as the target and no other target object is required.
For example with this 3D curve and no other objects:
Then running the Construct > Curve > Project command and clicking the "Use CPlane" button will result in this projection onto the construction plane, no other objects are involved:
10971.8
Hi there Michael, here is what I am getting using Project, with only the case of projecting against an object behaving as expected. Odd ...
https://www.youtube.com/watch?v=3732ycAvdjU
The test file is attached.
[edit] ... aaaand I am now realizing that even though "Top" is already selected in the list picker, the tool requires an actual click on the "Use Cplane" button to operate. That's all there was to it :)
For the sake of improved UX I would suggest to flip this around to put the operations in the natural left-to-right order : picking from the list (on the left), then pressing the button (on the right). Preferably with a disambiguation built into the text prompt guiding the user, stating clearly that the button needs to be pressed.
EDITED: 31 Jan 2023 by PIOR_O
Show messages: All  1-4  5-8
