Blending shapes not working
All  1  2-5
10967.2 In reply to 10967.1
without the complete 2 pieces (3dm) that is some hard to answer! ;)
EDITED: 25 Jan 2023 by PILOU
10967.3 In reply to 10967.1
Hi Edwin, I see the edit frame is showing on one of the edges. That likely means that you don't actually have an edge selected there, you've got a separate curve object selected there that is right on top of the edge.
Hide or delete the separate curve object so that you can select the edge.
10967.4 In reply to 10967.1
For something like a cylinder, select the "upper" round edge of the rounded part of the cylinder, not the edge of the planar circular top (if any), which would close the cylinder.
10967.5 In reply to 10967.3
hi michael.
yes, it was exactly like you said. had the curve selected and when i used both edges it worked fine.
thanks a lot!
Show messages: All  1  2-5
