Create ventilation holes/grid with Node Editor?
All  1-4  5-8
10963.5 In reply to 10963.4
Hi insekt,
> Is there something similar to Sub-D Multipipe in Moi?
No, not currently.
> If not, is there a workaround to achieve the same result, with or without the Node Editor?
You might check out TopMod:
http://people.tamu.edu/~ergun/research/topology/download.html
If you export out from MoI into .obj format then bring that into TopMod I think it has some different kinds of framing methods for generating structures around polygon edges.
If it is able to build an all quad structure you could then export that back out to an .obj file and use the MOI sub-d converter (SubD > Create > "From file") to convert it into NURBS geometry in MoI.
10963.6 In reply to 10963.4
Yep TopMod is a breeze! :)
Some trys ;)
https://issuu.com/frenchy_pilou/docs/topmodYep
OBJ is now a nurbs object! And here with a little Subdivision in Moi itself!
EDITED: 24 Jan 2023 by PILOU
10963.8
Alright!
It feels like I've had all my questions answered.
Thanks for your help, everyone!
Show messages: All  1-4  5-8
