API PointPicker without HTML UI
All  1  2-6
10961.2 In reply to 10961.1
Hi Joe,
> On the other hand, I haven't found a method to indicate that "I'm done selecting points" when
> you don't have a UI.
The way that is done in MoI is by having a a "Done" button. Then Enter or right-click in a viewport are shortcuts for pushing "Done".
Why are you trying to do it without any UI?
Without any UI the pointpicker will still generate a "cancel" event and waitForEvent() will return false when the Esc key is pressed, while a successful pick will generate "finished" so you could look for the cancel to stop picking points.
But it would be best to show UI with a "Done" button so it could behave similar to existing MoI commands.
10961.3 In reply to 10961.2
Michael
I appreciate your help.
My UI is running on a separate dialog outside the scope of `moi.command.execCommand()`.
For now, I'm gonna use `Esc`/`cancel`, albeit that was my actual cue to cancel...
10961.4 In reply to 10961.3
Hi Joe, if you want to have a "done" type button on your dialog you can have it trigger a UI event itself like this:
onclick="moi.ui.fireUIEvent( 'done' );"
This is done automatically for controls inside of the command UI (they generate a UI event using their id="" value) but you can also trigger it directly as well.
10961.5 In reply to 10961.4
Thanks...
That will work really well.
PS:
I know you must be super busy and appreciate your help, still trying to learn and still digging and finding a treasure of information in the forums. So just to add my grain of sand I started to document things in GitHub. It is still in its early stages, I'm mainly just dumping stuff, but hopefully, it will take form.
https://github.com/ctkjose/moi3d
10961.6 In reply to 10961.5
Hi Joe, thanks for collecting info on GitHub, I have added a link to there from https://moi3d.com/wiki/Scripting
Thanks, - Michael
Show messages: All  1  2-6
