Forum
All  1  2-6
Message 10960.2 deleted 22 Jan 2023 by BEMFARMER
To make text bigger, the HTML fontsize attribute can be used. (Kind of like the code /code window with greater than and less than signs.)
But maybe some members would find this objectionable? :-)
10960.4 In reply to 10960.3
bigger?
Lol…
10960.5 In reply to 10960.1
> How increase size font ?
All web browsers have a zoom control that allows you to change the text size that you are viewing.
You can look for a "Zoom" option in your web browser's menu or usually holding down the Ctrl key and moving the scroll wheel will do it as well. Also holding down Ctrl and pushing the + or - keys on the keyboard. Also usually Ctrl+0 (zero) will reset to the default size.
If you're on mobile then usually the pinch with 2 fingers gesture will do it.
It might be a little different depending on what web browser you are using.
10960.6 In reply to 10960.5
Yes I have this zoom but from years i am at 110% on Opera
I believe that i have press by error some keys...
For have same as before i must put the zoom at 150% ... that is some curious! :)
Show messages: All  1  2-6
