New six-legged pod video tutorial available.
All  1-8  9-14
the tut of the plane is maybe very good but the system of loading is not a model of facility ;)
1096.10 In reply to 1096.6
Hi Argonaute, I definitely agree that a tutorial covering the full construction of a detailed object would be valuable, especially without rushing through and skipping any steps.
I have tried really hard to not do that kind of rushing through style with these previous 3 tutorials.
The problem is that it is pretty difficult and time consuming to create tutorials in this way.
If I had another month or so to work full time just on tutorials, then that would probably be the kind of thing that I would try to produce.
But I've got to try and strike a balance with the amount of time that I spend on any one particular part of the product, including tutorials.
The current 3 tutorials cover a lot of the basics of NURBS construction like drawing curves, constructing surfaces from curves, cutting objects with booleans, and applying fillets - this should be a pretty good overall introduction to someone coming from a polygon background, because these current 3 tutorials do go through the full stages to create a basic model from scratch.
1096.11 In reply to 1096.1
Good work, quite instructive!
I didn't know about the symmetry features of the construction lines.
And amongst other things It clears up the use of the scaling rails in sweeps a bit, a feature I didn't play around much.
Regards,
Marc
1096.12 In reply to 1096.1
Thanks for the great tutorial Michael. It was good to see some of the tools that I hadn't used yet in action.
Nigel
1096.13
Great tutorial. Amazing 6 legged pod.
1096.14 In reply to 1096.13
even i dont have speakers at work i just understand everything, this is why i like this tut !
Keep on good work
Show messages: All  1-8  9-14
