Looking for a clever way to connect disjointed sketch lines
 1-12  13-32  33
10957.13 In reply to 10957.12
BAMMM!!! POW!!! ZAP!!!!
Holy Smokes Batman. Exactly like that!!!
You have made my month. Again!
Thanks.....
10957.14 In reply to 10957.13
I'm glad you like it Burr! :)
I need to make a couple of new options on the pointpicker to enable erasing by holding down the mouse button and dragging instead of only with individual clicks.
10957.15 In reply to 10957.14
That will be pretty radical too.
The "single click" mode is still very good for Precision work, so keeping that separate is good. Like "Shakey hands" or moving "Too quickly" may erase more that "1 inch radius"?
as long as single click can differentiate from "Moved a little"....
I had some fun using the "eraser" script.
It seems to work in 3 different irregular ways.
It makes round holes in surfaces, or solids, in one view.
Sometimes the curve needs to be closed and selected, but sometimes it works on an open curve, selected or not selected, or else "calculation fails".
For some curves it leaves behind a partial circular arc, sometimes a gap.
The descriptions swiss cheese and nibbler come to mind...
10957.17 In reply to 10957.16
“””””” Sometimes the curve needs to be closed and selected, but sometimes it works on an open curve, selected or not selected, or else "calculation fails".
For some curves it leaves behind a partial circular arc, sometimes a gap.”””””
Sounds like projection errors with the setup of the curves….
3d curves? Normal trims and booleans can do that when z values (or depth values) are introduced to the projection.
Can you make a file that does this?
10957.18 In reply to 10957.16
Hi Brian, yes it's mostly meant to be used on open curves. With closed curves or solids it is more of a swiss cheese effect.
There really isn't a whole lot to it, it's just doing boolean difference with a circle as the cutting object. On an open curve just pieces of the curve are removed while on a closed curve or solid pieces of the cutting object are part of the result.
The "Calculation failed" will happen if any of the candidate target curves are not on the same plane as the circle. if you run into this then select some curves that will be on the same plane as the circle so it only tries to target those.
Maybe it would be better if it automatically skipped over curves that are not on the same plane as the circle.
10957.19 In reply to 10957.18
Oh wow indeed ! This is so simple yet so useful. Thank you to all 3 for the suggestions, and of course for the Eraser script ! And I dont think I ever used the Blend command before, so thank you for bringing it up too.
All this may seem a bit tedious on the footage below but this is really useful. In my case it doesn't even need to be applied to the whole drawing, as only the most shaky and disconnected curves need correction (since the image is then rendered as raster pixels for coloring, and the rastering blends the lines that are already near tangent)
https://youtu.be/TsXEjCcV8iI
There is some slowdown when invoking it without making a selection beforehand, but that's to be expected.
I can't wait to try it while drawing, as opposed to doing it after the fact.
Perhaps ultimately the two operations (eraser then blend) could be rolled into one ?
I also wish Blend had the option to automatically merge the resulting 3 curves.
EDITED: 20 Jan 2023 by PIOR_O
Enlightening video i was perplex of what Eraser supposed to do!
Curious that was not yet existing! :)
So... ) Sorry in French but...
No need to show Points as shown in the video following!
You can click anywhere in the 3D Space!!!
And in any view!!!
Will be fine if the actual "Circle" eraser can be any form!
So...when you see the vertical "Circle eraser" it's because i click in another view than the 3D one! :)
EDITED: 20 Jan 2023 by PILOU
A temporary French one! ;)
Before without doubt some improvements fonctions of the Command!
https://moiscript.weebly.com/eraser.html
A terrific universal tool!
Waiting the use of any form as actual "circular" !
With curves! :)
EDITED: 21 Jan 2023 by PILOU
Seems there is a little glitch with the Points!
All are "erased" in the same time! :)
10957.25
WOW! great tool Michael currently working on a laser cut screen was looking for an easy way to handle the splits in the screen to hold bits together this tool with Max's FATLINES a powerful combo.
Ill post the screen result once complete.
Any chance this tool can make its way into the main toolset in future release?
Alex.
10957.26 In reply to 10957.25
Hi Alex,
It will be cool to see it!
Well, it's a big goal to keep the main program to not get bloated so probably no.
As shown here the Moi Export PDF don't takes the circles as a connected curves...
Will be fine to have something who makes all surfaces visible in any view (even empty faces) as connected!
...of course in this particular image i can redraw manually 3 circles...but...
(the Moi figure has just one default color)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/gag.pdf
10957.28 In reply to 10957.27
Yes, that's normal, particularly for the case you show where the circles are holes.
What are you trying to do with those circles where you want them to be a closed curve?
10957.29 In reply to 10957.28
Always the same! :)
Export to Affinity V1 for have only separated closed curves (or surfaces ) for any 2D design!
seems Aff V2 resolves now from no closed curves...(as shown on my previous video)
https://moiscript.weebly.com/uploads/3/9/3/8/3938813/fullsizerender.mov
It's legitim to have from any 3D view of a mechanical piece from a 3D prog only faces visible for any graphic post production...
In fact a sort of internal Contour Silhouette for each surface...
10957.30 In reply to 10957.29
Hi Pilou, for the circles that you showed above:
http://moi3d.com/forum/index.php?webtag=MOI&msg=10957.27
Those circles are holes. The nature of a hole is that there isn't anything in it, so it would be kind of strange to fill in those.
10957.31 In reply to 10957.30
Yes but its was just for take something and give the possibility in Aff 1 to fill anything...
I believe i can make something like this: Moi Export PDF "Project view 3D"
then reload this PDF inside MOi = i have a Plane of the visible wire!
General Trim by a Plane = i have each zone as a surface
Rest to find something who surrond each surface by a curve!
to be continue...
maybe this from the above! :)
Explode Move = free surfaces in the space
Select Edges and move them = I have only closed Curves !
UnMove
UnExplodeMove
Export PDF
here just export PDF for see if the closed curves works! :) (before the UnExplodeMove)
Filling in Aff 1 works now like a charme!
I believe i am near an easy process! :)
Show messages:  1-12  13-32  33
