On using dimensions as guides
All  1-3  4-11
10948.4 In reply to 10948.3
I should also probably add : merely being able to convert a line into a guide could be very useful. This might sound redundant/unneeded, but I find the input for creating lines (click first point, then click second point) to be a bit less error-prone than the click-drag input for creating guides (using ConstructionLine).
Or ... perhaps there is a way to create Guides in two clicks rather than click-drag ? This alone would probably solve my issues with permanent guides, and that would be even faster than having to convert things.
10948.5 In reply to 10948.3
Hi Pior,
> One other workaround I can think of : is there a way to instantly create two guides (one
> vertical and one horizontal) in the current 2D viewport or view plane, or even 3 guides
> X, Y, and Z), at the location of a currently selected point, or more generally speaking at
> center of the currently selected object ?
Sorry no there isn't any method for creating construction lines in these ways, the way
you can make them in MoI is by the drag gesture.
Sorry no there isn't a way to do that.
10948.6 In reply to 10948.5
Hello !
All understood, this makes sense.
On a related note : when placing dimensions (either Horizontal, Vertical, or Aligned), is it possible to invoke the tool in a way that makes it skip the last step (that is to say : bypassing the offset of the dimension object away from the reference points, setting it automatically as 0) ? I feel like this would be especially useful when laying down a series of Aligned dimensions at the beginning of a drawing when reproducing a part.
(I also wish it was possible to rotate an Aligned dimension after the fact by simply moving the point around like one can move the points of a line, but I don't think that's possible ? Of course regular rotate work so that's good enough obviously).
10948.7 In reply to 10948.6
Hi Pior,
There isn't currently any method set up to skip the offset in the regular command but it is possible to modify the command's script code to do that.
I've attached a version that does that.
You can turn on points for a dimension by selecting it and using Edit > Show pts, but the point manipulation will sort of stretch things out while keeping the same orietnation. If you want to rotate it you would need to use the rotate command or rotate handle on the edit frame to do that.
10948.8 In reply to 10948.7
Hello !
Well, what can I say - as always, thank you for following through and being willing to provide such helpful custom scripts. Being able to lay dims this way (without the legs/offset) really fits with the way I think of drafting - that is to say : being accurate early on (to an extent ...), but without obsessing over fully constraining everything. This is great.
One last suggestion I would have would be the ability to edit a dim not just as its X and Y, but also being able to input the actual dimension like one can do with regular line objects, as shown (or rather, not shown) on the dim being actively edited in the screenshot above. And of course (as mentioned earlier in a different thread IIRC), perhaps an option to temporarily display the dimensions of everything on screen as an overlay could be useful too.
All understood about rotation - I do tend to mostly use the rotate tool anyways (as opposed to using the edit frame, or direct manipulation of points), so that's perfectly fine.
EDITED: 15 Jan 2023 by PIOR_O
You have not the same result if you Left click twice without move at the second extremity with the normal Aligned Dimension ? (not a big deal)
And Horizontal and Vertical Dimension are necessary ?
Because seems Aligned command can do the same ! :) (if i am right)
Else no more tricky than this for a 3D Dimension anywhere in the 3D Space ?
OK you can make the same with a CPlane but needs 3 views, an headache for take the good CPlane! :)
(move the axes etc...
So rustic method above is more easy! :)
10948.11
I well am aware of how the Dimensions tools operate, that's not the point. As the title suggests, the topic of this thread was to explore ways to use Dims as a drafting tool, which in turn led to the very useful script provided by Michael streamlining their creation process by automatically skipping the last input (legs/offset). And therefore, making them much more intuitive to lay down as a scaffolding for a precisely dimensioned drawing.
Show messages: All  1-3  4-11
