API issues moving windows
All  1-4  5-11
10946.5 In reply to 10946.4
Hi Joe, it's probably because calling moi.ui.createDialog() is asynchronous. When you're calling
So probably you'd need to put the call to .move(x,y) inside the dialog in an onload="" handler.
What's probably happening is the call to .move(1, y) is happening before the dialog is finished loading and it is going to position the dialog when it is finished loading and that then wipes out the initial move.
10946.6 In reply to 10946.4
Hi Joe, re: moving window - maybe what I should do is if a script calls .move(x,y) on a window before it's been loaded and displayed I can store that and position the window there after it's been loaded instead of putting it in the default position.
10946.7 In reply to 10946.5
i already tried that, using a setTimeout in the dialog’s html after/before the windows load/ready event.
10946.8 In reply to 10946.7
Hi Joe, so a dialog will fire a 'display' UI event when it's finished loading so it should be possible to wait for that to happen before calling .move(x,y) on it.
Try like this:
var dlg = moi.ui.createDialog( '<html><body class="DialogBody"><div>testing</div><div>testing</div><div>testing</div><moi:DialogClose/></body></html>' );
while ( dlg.waitForEvent() )
    if ( dlg.event == "display" )
        break;
dlg.window.move( 10, 10 );
I have also got it set up for the next beta so that if a script calls .move() or .resize() on a window before it has finished loading it will record the given position or size and apply it after it has loaded.
10946.9 In reply to 10946.8
@Michael
var dlg = moi.ui.createDialog( '<html><body class="DialogBody"><div>testing...</div><moi:DialogClose/></body></html>', 'resizable,defaultWidth:350,defaultHeight:200' );
while ( dlg.waitForEvent() ){
        break;
1. I was wondering if you can share a bit more info on what's going on behind the scene. I'm trying to write my plugin with more asynchronous code, promises, and callbacks, and attempting to use `createDialog` for something it was not meant for, ie: panels and toolbars.
I can get `resize()` to work but not `move()`...
After doing some testing I notice (speculating) the following:
- The HTML view (QT WebView) is loaded and all of the rendering and DOM events are completed, prior to the dialog's "display" event. You can manipulate DOM/window without issues at this point.
- I'm speculating that the window/QT layout is modified after the WebView's triggered the load completed, something along the lines of `restoreGeometry`, `restoreState`. The window is centered (relative to the main) (as an expected behavior of a dialog) and window dimensions are restored.
- After that, the `display` event is triggered.
- You can handle the "Esc" in javascript, it always dismisses the dialog.
2. I have a couple of wishes/ramblings!
It would be cool if you add a couple of signals to your QTObjects, that would make this type of interaction more event-driven.
In createDialog() there could be additional window parameters to control its behavior, or maybe a new openWindow() function like
var dialog = moi.ui.openWindow(html, 'resizeable,defaultWidth:380,defaultHeight:420,isModal:true,isCentered:true,style:Dialog,title:My Dialog', moi.ui.mainWindow );
In this example, `isModal ` means that it blocks interaction with MoI until it is dismissed (Qt::ApplicationModal).
Style control the layout and window type like Qt::Window, Qt::Dialog, Qt::Tool, Qt::Popup, etc. Allowing the FramelessWindowHint would be cool to do HUDs and overlays.
===EDITS ====
More observations
`defaultWidth` and `defaultHeight` only work the first time the dialog is used, subsequent calls to the same code/command ignore these values. They work if the actual HTML contents or the URL changes from the previous call.
re
I actually did that, I tried two approaches, one would concatenate JS code that would be executed after the `display` event, sort of like a jquery "ready" function. The other would store properties in the window object with a flag to resize/move. Among others, the object would have things like minWidth and minHeight to limit `resize` (you can not change the size by code unless the window has resizable property).
The `resize()` works, but `move()` never worked.
EDITED: 23 Jan 2023 by CTKJOSE
10946.10 In reply to 10946.9
Hi Joe,
Is it possible that the coordinates you are giving to move() are not at a visible point on the desktop window? Maybe the y coordinate in particular is underneath the Mac top menu bar.
What happens if you try running this version:
        break;
dlg.window.move( 100, 100 );
You can do a modal dialog by calling dialog.window.doModal(); after moi.ui.createDialog(). That will call setWindowModality( Qt::WindowModal );
You can use var menu = moi.ui.showMenu() to create a Qt::Popup window with FramelessWindowHint instead of a dialog.
The options you can currently set for a dialog are:
resizable, fixedWidth, fixedHeight, defaultWidth, defaultHeight, and noCloseButton.
10946.11 In reply to 10946.10
@Michael
Thanks for directing me in the right direction. My values were always positive, but kept trying and figure out the issue is MacOS's Menu Bar.
I have to keep my "Y" above 24pt (in Big Sur and above).
Show messages: All  1-4  5-11
