Scripting API
All  1  2-4
10944.2 In reply to 10944.1
Hi Joe,
> PS I also wonder what js engine is used in MoI, is it V8, duktape, mugs, etc?
It's JavaScriptCore that's part of WebKit.
re: Scripting points - MoI v4 does not have an interface for scripts to access object points but there has been some stuff added in for the current v5 beta for that.
You can get the v5 beta at https://moi3d.com/beta.htm , and the info is in the V5 beta release notes: https://moi3d.com/wiki/V5Beta , it's this part:
quote:
Edit points scripting - Add scripting interface on objects for:
    obj.hasEditPoints - read-only property true if object has edit points, false if not.
    obj.hasSelectedEditPoints - read-only property true if object has any selected edit points.
    obj.numEditPoints - read-only property for number of edit points.
    obj.getEditPoint( index ) - method that returns an x,y,z point for the given edit point index.
    obj.getEditPointSelected( index ) - method that returns true if the given edit point is selected.
There may not be enough stuff in there yet for editing the points though, you would need to select it and then use the Move factory to create a new object with a moved point. Although you can read selection currently there isn't a set selection yet.
10944.3 In reply to 10944.1
Hi Joe,
Welcome to MoI!
In case you've not seen it, do see the thread on some API documentation that the community has contributed to:
https://moi3d.com/forum/index.php?webtag=MOI&msg=10857.36
The release notes also contain references to scripting changes:
https://moi3d.com/wiki/V3Beta
https://moi3d.com/wiki/V4Beta
When posting code snippets on the forum, adding code tags makes it much more readable by preserving your formatting.
<code> ... </code>
--Larry
EDITED: 7 Jan 2023 by FAHNOE
10944.4 In reply to 10944.3
@FAHNOE
Thank you for sharing this info. I have in fact been digging deep on the forums and digesting all the great scripts I find from the community.
Matter of fact I started a GitHub repo to document and gather everything I find. It's WIP but I try to work on it every time I can.
https://github.com/ctkjose/moi3d
Show messages: All  1  2-4
