Lumber script makes standard dimensional lumber
All  1-5  6-11
10941.6 In reply to 10941.1
Cool Larry - I could have used this when designing my gas fireplace framing in MoI last year. I hate fractions :)
10941.7 In reply to 10941.6
The idea came to me *after* I did a model of a pole building...lots of dimensional lumber. Such a simple script to make that task a bit easier and less error prone.
Nice model Ed!
--Larry
10941.8 In reply to 10941.4
On the Elephant Repository, on my site, and on some pages I assume yes !)
On the Wiki itself I don't believe...it's too time consuming to Edit...
10941.9 In reply to 10941.5
@Larry
OK I see now! :)
Not a big deal to make this script in French! :) Done!
https://moiscript.weebly.com/portes-et-fenecirctres.html
EDITED: 6 Jan 2023 by PILOU
10941.10 In reply to 10941.6
That fireplace looks really nice. I was looking real close how you did your layout.
So awesome seeing Moi3D being used like that. Most of the time I just draw up parts and pieces to 3d print.
Thanks for showing this functional schematic Ed. I have started drawing up shelving that I plan on making.
Larry's Lumber dimension script will be very helpful. Thanks again.
10941.11 In reply to 10941.10
Thanks Specktech - Yeah, some folks could build that using just a rough hand sketch - not me :) There were some critical dimensions for framing and venting that needed to be met in order to pass inspection, never mind that when the fireplace was delivered it needed to slide in perfectly with room to attach gas & electrical. It really helped to be able to rotate the 3D model and see it from all sides. When cutting a 10" vent hole through your wall, you really want to be sure it's in the right spot :)
Show messages: All  1-5  6-11
