Create helix with a profile
All  1  2-4
10940.2 In reply to 10940.1
Hi Joerg, set the option for Twist = Flat in the Sweep options:
Then additionally push the "Set flat direction" button that appears in the options once Twist=flat is set, and pick 2 points along the y axis to tell it the direction:
When twist = flat is set, the profile will only rotate around the given axis direction. The default axis is the world z axis, since your helix is aligned to the y axis instead that's why you need to use "Set flat direction" as well.
10940.3 In reply to 10940.1
Take 2 Rails ?
EDITED: 5 Jan 2023 by PILOU
10940.4
Hi Michael hi, Pilou,
Thanks a lot for help!
Joerg
Show messages: All  1  2-4
