Create helix with a profile
10940.1
Hello,
First, Happy New Year to all!
I am just sticking to a very simple task creating a helix and using the helix as rail to sweep a profile. I have no issues when using a circle as profile, but if using a asymmetrical profile, the profile gets slowly rotated out of the orientation at the start. (Hard to explain in words, therefore I attached some screenshots.
A similar effect can be seen when creating a circular array by copying the profile along a curve (given by the helix).
How can I keep the straight side of the profile parallel to the helix centerline?
Thanks for any input in advance ;o)))
Joerg
Size: 108.3 KB, Downloaded: 24 times, Dimensions: 637x481px
Size: 94.7 KB, Downloaded: 18 times, Dimensions: 739x609px
Size: 68.5 KB, Downloaded: 27 times, Dimensions: 557x500px
10940.2 In reply to 10940.1
Hi Joerg, set the option for Twist = Flat in the Sweep options:
Then additionally push the "Set flat direction" button that appears in the options once Twist=flat is set, and pick 2 points along the y axis to tell it the direction:
When twist = flat is set, the profile will only rotate around the given axis direction. The default axis is the world z axis, since your helix is aligned to the y axis instead that's why you need to use "Set flat direction" as well.
10940.3 In reply to 10940.1
Take 2 Rails ?
EDITED: 5 Jan 2023 by PILOU
10940.4
Hi Michael hi, Pilou,
Thanks a lot for help!
Joerg
